SL55/63/65/R230 AMG: Help!
Sorry for your loss ERC, You sound like a good daughter.
Drive the sl and remember your dad.
perhaps someone in your area on the board can recommend a better dealer.
Are you plugging your battery charger into the cigarette lighter socket because if you are, you will need to leave the ignition key turned to the first position for it to charge.
I connect a voltage controlled charger straight onto the battery in the back.
My car sits unused from the end of October through winter till the end of March without problems. I start it once a month.
Get your dealer to check if there is an oil leak on the suspension unit on the dropping side, they are notorious for going wrong and leaking.
