SL55/63/65/R230 AMG: Shifting the SL55
2004 SL55, 2005 E500 Wagon
Shifting the SL55
When I first got my SL55, I was coming from a manual transmission, and I was a little disappointed. At first I tried it in manual mode. The delay in shifting, while less than in most manumatics, made shifting at a precise rpm difficult. Shifting just at the redline under full throttle was essentially impossible; either I’d shift too soon, or run into the rev limiter. Even though the lag affected downshifts as well, they were not a problem, since you make them going in to a corner under a trailing throttle and their exact time of occurrence is not important, as long as you don’t get the car out of shape with engine braking at the wrong time.
Then I started playing with “S” or sport mode. I’d go into a corner and around the time of turn-in (the exact timing varies with the radius of the corner) tap the left button enough to get the car in a gear that I wanted to be in when I started to apply power. (If you’re going to be at a fairly high rpm after the last downshift, you want to shift later, since there’s no rev matching software on the SL, and we don’t want to unbalance the car any more than you have to.) Then you point the car just inside the apex and squeeze on the throttle. As you pass the apex and begin to unwind the steering wheel, tap the right button to allow the car to change to up to the gear that you’ll want at the end on the corner. Stay on the throttle as much or as little as you want, and let the transmission upshift for you. If you’re feeling racy, burying the throttle will give you perfect red-line shifts. If you’re giving the car less gas, you get appropriate shifts.
In summary, you control the downshifts, and let the car control the upshifts. Works great for me. How do others do it?
Jim
Jim
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Jim:
You sound like a man after my own heart. The SL55 to me is a brilliant driver's car, and not really a drag racer.....which is what most of the people on here tend to do.
As for me, I have very rarely used the car in auto mode. I generally drive in manual/sport/ABC in sport and traction control off. Maybe the car has 'learned' what I like, because the more aggressive I am the quicker the shifting. It would be nice if it had some rev matching software for downshifting. Hell, my little M3 SMG has it, as does the 360 Challenge Stradale that I am loking at.
mymbonline
thats also what i do, although i try to rev match on downshifts
there is no point in ****ing w/ manual mode. its just not quick enough, by the time it downshifts your running into the rev limiter because youre already exiting the corner
My autobox (comfort/sport/manual) upshifts automatically @ redline. I have yet to encounter the rev limiter. My SL55 is form 2002, so I guess the software changed over time.
Also the steering wheel shift buttons do nothing when not in manual mode. While in my S55 they shift like the +/- on the gear handle.
An Affalterbach Beast & Others
At first, I would drive the car religiously in manual mode, but over time I just fell out of the habit and I haven't pushed the buttons in months. I'm just not a fan of the buttons and feel that it isn't natural for the car and it feels like an afterthought, I know for sure if the '07 paddles were in front of me, I'd be back to my old ways. I think the auto mode shifts excellent and is better than most high-performance auto boxes.
Jim
The right time to downshift is well before the apex. In auto mode, the transmission can't know that you are nearing the apex, and won't downshift until you apply enough right foot that it knows it needs to downshift to get more torque to the tires.
Jim
I'm just not a fan of the buttons and feel that it isn't natural for the car and it feels like an afterthought...
OTOH, I find them perfectly positioned so I can shift with my middle fingers. If they were further out from the wheel then they wouldn't always be under my fingers and I'd have to reach for them.
Jim
I had some further thoughts.
1) When I was driving a stick, I always wanted to get my downshifting done before turn-in. Maybe I'm not a great heel-and-toer, but it was really hard for me to be coming out of the brakes the way you have to do when you trail-brake, and shift at the same time. In the SL, without the need to heel-and-toe, I can shift a bit later. This means that the revs are a little lower, and there's less unsettling of the car due to the lack of rev-matching software in the car.
2) I tried rev-matching myself, and I can't do it because I can't tell exactly when the car is going to shift.
3) I have an E500, and this approach doesn't work there for three reasons: a) it's not much fun to flog the car hard, b) you don't know what gear you're going to be in when you hit the shifter, because of the way the transmissio software is written, and c) you don't want to take you hands off the wheel to upshift when the g-forces are high.
Jim
leave in "s". let the 5 speed do its thing. concentrate on your racing line.
the boat the r230 is and the gobs of tq at any rpms makes it largely not worth fiddling with the tranny during track days.
remember - if you are in the r230 amg at track day you are already doing it wrong. enjoy passing in the straightaways and the pucker factor understeering in the turns and be happy
precisely
you're supposed to already be in the right gear before entering the turn.
