SL55/63/65/R230 AMG: Tires Rubbing?
Old Nov 10, 2006 | 09:40 AM
el gato's Avatar
ML63
Tires Rubbing?
I need some help. I just bought a set of used HRE 547r's used from another sl55 owner. The rears are 19x11.5 with 295/30 19 Conti's that rub when when the suspension compresses. Anybody have any suggestions other than that I got screwed? Thanks
Old Nov 10, 2006 | 01:23 PM
jmf003's Avatar
'03 SL55
TireRack shows 285/30 as being the correct size for 19" wheels on an SL, so you are slightly oversized with the 295/30s.
Incorrect offset can also compound the issue.
Old Nov 10, 2006 | 09:37 PM
rottordam's Avatar
sl 55, e500, x5 4.4
ditto, cant go bigger than 20 if going higher than 285, but maybee some very aggresive alignment and rolling the fenders will solve, but that can cause more $$$ damage than just getting new rubber
Old Nov 10, 2006 | 11:40 PM
AMG_55's Avatar
mymbonline
my uncle has a sl500 w/ 20's and he's running a 305 on the rear no problem.
his car is also slammed.
you got the wrong offset.
you can have a machine shop shave the hub on the wheel if you still have enough room to clear the brakes (i dunno how big the lips are etc....).
if you cant do that then roll your fenders, although i believe all amgs have rolled fenders, sometimes there is a little that sticks out, it did on mine and i just had a shop cut it.
goodluck
Old Nov 11, 2006 | 12:23 AM
AZAMG's Avatar
SL55
I have 20X11 rears with 305/25 Conti's on 03 SL55. Lowered, no rubbing.
Old Nov 11, 2006 | 02:16 AM
idrive's Avatar
2017 SL63
295-30-19 - no problem with the lowered suspension.
Did you ask thye guy if they rubbed on his car???
Gotta be about the offset.
