SL55/63/65/R230 AMG: Supercharged SLK55 VS Stock SL55
Kleemann SLK55
Price: $85,000
HP: 580hp (~500whp)
1/4 mile: 11.7 (C2 design SLK55 S8)
Transmission: 7 speed
Weight: ~3,500lbs
SL55
Price: $120,000
HP: 500hp (~430whp)
1/4 mile: 12.5 (car and driver)
Transmission: 5 speed
Weight: ~4,300lbs
On paper, it is clear that Kleemann SLK55 is far superior. Nearly 1,000lbs lighter, 80 more hp, 7 speed transmission, better weight distribution, etc. Not to mention, there are no controversial ecu recalls that may decrease performance on the SLK55. So, can someone explain to me why you think SL55 is worth 30,000$ more? The only reason I can think of is SL55 gives you warranty, while supercharged SLK55 will have its warranty voided. However, I haven't heard one single complaint against kleemann superchargers, they have been tested to over 50,000 miles in the SLK55 /w 7 speed and no problems.
P.S. I clearly understand why SL600/65 is better than SLK55, however, lets keep to "supercharged V8 in SLK body VS supercharged V8 in SL body". Remember that V12's are way more expensive...
Does the SLK have the same brakes, suspension, Navagation System, etc. as the SL???? I dunno.
If it does, then there is merit in upgrading...........if not, well, then.......................go fish.
Dave
Dave
That and the voided warranty on an 85k ride, no thanks
If i wanted cheap power, i'd get a Z06...
Kleemann SLK55
Price: $85,000
HP: 580hp (~500whp)
Weight: ~3,500lbs
SL55
Price: $120,000
HP: 500hp (~430whp)
Weight: ~4,300lbs
.........kleemann supercharged fully loaded C55 is faster, lighter and much less expensive than an S55. My point is that you can go on with this analysis for ever. SL55 is worth more because of its intrinsic value. The blue book value, trade-in value or retail or whole value for the SL55 is more. The Kleemann s/c adds no value to your car. The SLK55 with the Kleemann s/c is not worth more on the open market than a stock SLK55.
.........people might prefer and thus give more value to the SL55 because other subjective reasons. Some might prefer the more muscular look of the SL55 compared to the girlie look of the sLK55. Some might prefer the prestige of the SL55 and thus give it more value. Bottom line, buy the car you like and enjoy it. There WILL BE another car better, faster, more expensive than yours. They WILL even be other cars slower than yours that others will like much more than yours.
Ted
a little question to you guys, if the SL has all the "muscular looks", why it appears as the top 10 gayest car in the web?
That is easy,
The car exherts enough Charisma to suggest a Giant Streamlined Dick Slicing Thru The Air.............that would appeal to a gay person, imo.
And as far as performance goes, even Mercedes knows how close the SLK55 is to SL55, why else would they claim 0-60 for SLK55 as 4.8 and SL55 as 4.4, when in reality, both achieve 4.3 seconds? How can you compare this to C55 VS E55 VS S55 situation? Does C55 post the same 0-60 times as E55 stock? I think not. Now imagine what SLK55 can do with a supercharger! We're talking easy sub 4sec and mid 11's all day long, while also providing all the same features as SL55. All for way less cash.
Also, ECU flashing doesn't void warranty iirc...
P.S. And pulley/ecu does void your warranty. Mercedes could care less if you blow up your engine due to higher boost from pulley/ecu or an aftermarket kompressor, you're screwed either way. Changing ECU without pulley makes no sense, and 99% of people who flash ECU do pulley as well.
........if you want an SLK55, then get one. Don't try to justify it to others, because not everyone is as enamored with it as you are. An SLK55 with a Kleemann s/c is faster than an Gallardo, but many prefer a Gallardo and will pay more for it. Many people likewise prefer the SL55. Infact the SLK55 with a Kleemann s/c is probably as fast as an SLR..........well, you get the point.
Ted
Ted
Good luck.
You're talking about two different classes here, you can compare them, but to try to justify the SLK55 whooping around the SL55 is kinda foolish because the arguement isn't worth anything.
It's like the owner of a C55 talking smack about the S55. What purpose does it have except to stroke ego's? In the end of the day, the S-Class (parallel this to the SL) is a larger car, and to some eyes more comfortable. You just have to find the car that's right for you at any given time.
The SL 55 AMG is the easiest car to drive fast on the street............in real-world terms/situations............that I have ever driven........much less owned.
Power is effortless.
Car's Driver input/fedbaCK is superb.
Rado works..........
140-150 is like 80 in my Supercharged Ford F-150 Pick-Up.........and that truck will run 140MPH up top.........(Procharger-10 lbs. boost) and is well tuned..........
But, a Haywagon of a Truck is not a Race-Car and my Ford is a Haywagon at 130 or more.....................the AMG is pure adrenelin on wheels.........130 is warm-up speed, IMO............
Input????????
But that's me. If the cars seem nearly identical to you in terms of form, feature, and function then the SLK is the right choice for you. Go buy one, mod the heck out of it, and report your results back here.
