SL55/63/65/R230 AMG: Any ESP issues w/ 10 mm wider front tire?
Old Oct 1, 2007 | 04:29 PM
DoctorV8's Avatar
2005 CL65
Thinking about running a 255/40-19 instead of the factory 245 on my '05 CL65. Never had any issues with much more substantial circumference changes on my other cars, but the sales rep is convinced that I will run into ESP issues.
We're talking about a difference of 0.3" in overall diameter here. I can't imagine that this is an issue.
Thoughts? Experiences?
Old Oct 1, 2007 | 05:21 PM
ohlord's Avatar
4/10 in wider
3/10 in taller,8 revs per mile fewer.All pretty much in the range of just some different brands measurements for the 245/40/19's so no it won't make a difference.Your distance traveled per the same engine rpm will be 56 more feet.In 5280 ft. that is what about? 1%
Old Oct 2, 2007 | 09:56 AM
erdocslx2's Avatar
Veteran: Army
2016 s65 Coupe, 2024 GLE53C, 2020 S560
I did not have an issue with the esp but make sure you current tire is not too close the the portion of the suspension that actually curves out over the tire. Had an issue with larger rubber rubbing on this and groving the tire. The tire that matched factory on mine has very little clearance and an additional 4/10" may be enough to make it rub on turns.
Old Oct 2, 2007 | 11:16 AM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
The ESP will allow a difference of 5% of speed , before complaining.
I am running 275 up front, without any issues.
Old Oct 2, 2007 | 11:24 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
No problems with my oversize tires and 19s
