SL55/63/65/R230 AMG: what size tires for 20" wheels
Old Oct 23, 2007 | 05:21 PM
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
Hi I have lowenhart 20x9 and 20x11 what size tires are best for the 2004 SL55 amg I am thinking 245/30/20 for front 285/30/20 for rear. Any suggestions thanks Jason
Old Oct 23, 2007 | 06:01 PM
rbtronnie5's Avatar
You name it i've had it or got it...
245 or 255-30-20 in the fronts and 305-25-20 rears
Old Oct 23, 2007 | 06:52 PM
erdocslx2's Avatar
Veteran: Army
2016 s65 Coupe, 2024 GLE53C, 2020 S560
285/30/20 Are too small for the 11's. you need at least 295/25/20 but rbtonnie5's recs are perfect.
Old Oct 24, 2007 | 04:22 AM
maxabo's Avatar
2008 MB CL600. 2020 MB E300 de. 1987 BMW M535i.
I agree.
My 285/25-20 are to thin.
At least 295/25-20 to get them as high as my 245/30-20 in front.
And strangly enough, there are some differencies between 285 and 285, depending on what brand the tire have...
I can't get that!
Old Oct 24, 2007 | 04:51 AM
maxabo's Avatar
Totally forgot to tell you the width of my rims. 9" front, and 10" rear.
And since you have 11", 305 sounds ideal.
But as I said, there are some differencies in width depending on tire brand...
Old Oct 24, 2007 | 01:48 PM
rajah996's Avatar
CLK55, CL500, Q45
What tire pressure do you guys run? I have 20" RennTech's
with 295's on the rear. Tires are PSII's. Thanks.
Old Oct 25, 2007 | 08:23 PM
bigred's Avatar
sl55
i have 20x9 & 20x11 255's on frt & 305's rear, guy at tire shop said they should be at 51psi but im not sure
Old Oct 26, 2007 | 09:45 AM
rajah996's Avatar
CLK55, CL500, Q45
Yeah a tireshop told me 46 and I thought that was a bit high.
Old Oct 31, 2007 | 08:32 AM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
[quote=cdsjklee;2468119]Hi I have lowenhart 20x9 and 20x11 what size tires are best for the 2004 SL55 amg I am thinking 245/30/20 for front 285/30/20 for rear. Any suggestions thanks Jason[/quote]
You can easily run 275 up front, and 305 rear. Those tires would match the rims perfectly.
The 275 gives a better grip, when cornering, and braking.
Its true that tires differ in actual with from brand to brand, i noticed that my self, so what i recomend is Conti Sport Contact 3. They have a smooth ride, good grip, and are not square when its cold.
They handle my 654 hp. very well.
Old Oct 31, 2007 | 11:39 AM
Fantasm's Avatar
Car Whore
hey SLcharger, post some pics of your car
Old Nov 1, 2007 | 09:47 AM
SLcharger's Avatar
[quote=Fantasm;2480379]hey SLcharger, post some pics of your car [/quote]
Sure, just need to give it a wash.
Old Nov 1, 2007 | 12:47 PM
rbtronnie5's Avatar
weird....you learn something new everyday. i wonder why no one else runs 275 up front and 255 has been the standard? your car doesn't rub because it is lowered?
Old Nov 2, 2007 | 11:19 AM
SLcharger's Avatar
[quote=rbtronnie5;2482303]weird....you learn something new everyday. i wonder why no one else runs 275 up front and 255 has been the standard? your car doesn't rub because it is lowered?[/quote]
Havent had any trouble yet. Have done more than 10K miles with that setup.
