SL 55 rear suspension problem
Subscribe
Jul 16, 2008 | 09:04 PM
Hi everyone,
i am new to this forum, glad to meet all of you MB lovers!!=)
i am currently driving a 2003 SL 55, and it never had any major problems except the "ESP Failure" massage pops up on the dash screen. i was told by the dealer that i have to change the suspension fluid pump becasue it's leaking. But is it true that MB is offering 10 years warranty on that pump now? also i started to relizes that the height of the rear suspensions were not level, one 1/2 to 3/5 inch higher than the other. have any of you guys had similar problems before?
Reply 0
Jul 17, 2008 | 12:44 AM
ABC (active body control) is your suspension system. The pump for the suspension does commonly go out as well as the valve blocks for your suspension ride height control. The faulty valve blocks would cause the suspension to drop or change ride height.
ESP (electronic stability program) is your traction control system. A faulty suspension pump would not cause your esp light to come on.
SBC (sensotronic braking control) is your brake by wire brake system. This is the system/pump that has the extended 10 year warranty.
Sounds like there is some misinformation going on here. Probably due to poor communication between the technician, the service advisor, and yourself. Go back and get a clear explanation of the condition of your vehicle.
Reply 0
Subscribe
Currently Active Users (1)
