SL55/63/65/R230 AMG: TPMS Question
'06 SL65
TPMS Question
This weekend when I turn off the engine on the SL65 the TPMS indicator symbol is shown on the dash display under the speedo and under the tach the display says "Please Rectify Tire Pressure". It only happens after I turn off the engine. I've checked the pressure and all the tires are within spec. I also tried to reset the tire monitor but still shows up. Is this a bad tire sensor? Any info would be greatly appreciated. TIA!
2018 SL 65 AMG 2017 GLE 63S 2015 RAM RT
Had this happen on my CL63 . Stopped by Discount Tire and added some air to each tire. Have not had the display since then. This happen about a month ago.
'06 SL65
Funny you mentioned it.....I actually brought it to my buddy who's the manager at Discount Tire near me and he checked out the pressure and found everything was to specs and no nails but I'm still getting the display.
06' E500 Estate, '08 S65, '05 S430
I had this happen with my SL55. The first time it was a bubble in the tire. The air goes into the bubble periodically and then comes back into the tire. The TPMS display would jump up and down up to 5 psi when this happened. The bubble was on the inside of the tire, so I did not see it. It's from a pot hole.
The second time, the sensor or the receiver unit went crazy. It was in the dealership for a few days before they tracked it down. Each wheel has a sensor/transmitter and there is a receiver in each wheel well.
J
'06 SL65
Thanks jeffreyy for the info. I don't think I've hit any potholes....at least that I remember of. I'll stop by the dealer this week to have them take a look at it.
