SL55/63/65/R230 AMG: sl55 interior lighting
Old Nov 16, 2008 | 03:14 PM
tmo1113's Avatar
2003 SL55
i have a 2003 sl55 and tried to put leds on the interior... everything was going fine until now... nothing on the interior lighting will work EXCEPT for the door lights... also my key fob is not working.. any help please.. thanks
Old Nov 16, 2008 | 04:24 PM
tmo1113's Avatar
2003 SL55
anybody?
how about the fuse chart because mine is not located in the car.
Old Nov 18, 2008 | 03:41 PM
URnext's Avatar
SL55 AMG
I am working on the same project. For the lic plate light and foot light area are going to need capacitors. I believe the correct ones to buy are 5 watts/100ohms. You will need to splice the wires and install them. You can find a lot of info on this site using the "search" button. Also there is a lot of info on this topic on "mymbonline".
Good Luck
Old Nov 24, 2008 | 04:32 PM
tmo1113's Avatar
2003 SL55
Yes this I know but it seems that there was a thrid fuse box located almost under the battery this is why I was asking about a fuse chart. And I did alot of "searching" on this site trying to find someone with the same problem as I was having but no luck. Well I hope that if someone in the future has this problem they will now know (at least in my situation) that A) it was a fuse & B) there is a fuse located next to the battery (under the hood)
Funny thing the owners manual never mentioned this fuse box that I needed to access, neither did alot of the forums I visited and searched.
