SL55/63/65/R230 AMG: A question to the experts ref upgrades
Old Jan 9, 2009 | 12:45 PM
bosch man's Avatar
SL55 AMG
..as you may have seen i have had the "600" conversion by dms,now they did the pulley change and a remapped ecu...now how good is the ECU in the sl55...for example this is of course an off the shelf map..one map for all sl55's on this conversion so obviously the orignal car they used to get the map right is now copied...how safe will it be i mean does the ecu retard the ignition if it gets too hot,leans out etc is it sophisticated enuff assuming map is good not to blow my engine up if a drove it flat out?
