SL55/63/65/R230 AMG: Max RPM SHift points when using "M" mode..
I find if I wait till close to redline and hit the up button there is some lag in the actual shift , the car hits the rev limiter as it goes up a bit in RPM, then bogs then goes into 2nd, or the higher gear. My foot is on the gas the whole time.
I'm wondering if there is a better technique or I should hit the upshift earlier in the range and it would then the car would shift right around red line, or let up a bit off the gas similar to a normal stick shift then floor once in gear again?
any feedback would be great. thanks
the "M" button is strictly for forcing a downshift (or two) when at part throttle and you want to accelerate faster, but not floor it for a kickdown.
alex
few cars
you can also explore with turning off stability and letting it activate when flooring... some cars achieve better 0-60 with this technique.
or you can feel adventurous and put the car in dyno mode (no electronic help of any kind including abs) and experiment... but be careful
alex
few cars
