SL55/63/65/R230 AMG: Goodspeed Twin cooler kit for the SL65/SL600
After countless hours of research and development GoodSpeed is now offering the F-pak twin cooler system for the V12 twin turbo Mercedes cars.
This system is the only system that can beat the Arizona heat, and is perfect for cars running more than stock boost. We have also introduced a solution to the perfect pump issue that has been a down fall of the stock system from day one. As one can see from the dyno chart below we achieved a 20 degree intake air temp drop with no other modifications than our kit and this was in 100+ ambient temperatures, and yes, it was middle of the summer in Arizona when tested. You can also see from the dyno graph that our test car was pulling timing due to detonation from high intake temperatures resulting in substantial loss of power and torque. This was no longer a issue after the installation of the F-pak kit. The F-pak kit is also very stealthy, almost undetectable from the front of the car. The entire F-pak kit is designed and built to fit with no permanent modification and NO trimming of any stock components. OEM in fitment, with all premolded hoses and a preformed wiring harness that runs with factory looms.
As most owners of these cars in hot climates know, summer time is a time of lost power and a overall feel of sluggishness for their V12 turbo powered Mercedes, and even modified cars with software and intake seem to lose all the power that was gained. This kit gives that power back and allows the car to make the power it was intended even on 91 oct fuel.
For more information contact Goodspeed at 480-747-6150
Kit list
1 heat exchanger with splitter
1 set of pre molded heat exchanger hoses
1 one radiator relocate kit including pre molded hoses
1 pump set
1 wiring harness with relay pack
All brackets and hardware
Introductory kit price will be $2300.00 installed. Kits at this price are limited.
Kit for AMG SL55 will be coming soon as well as S and CL class AMG cars.
