SL55/63/65/R230 AMG: ASP Idler pulley saved me big $$$$$.
If this pulley breaks, you are SOL.. You loose both belts and car will be un-able to drive.. At best, parts fall on the ground and do not sling threw the hood of the car or cause other damage.. Most of all, this idler pulley is sold as a set by MB for close to 400.00 bucks!!
Signs of a bad idler are squeeking noise at start up and wobbling when you twist it with your hand..
I sent by stock pulley to ASP and they machined up a new heavy duty Idler pulley out of billet aluminum. They said bearings are now Z rated wich can handle higher RPM than the stock bearings.. I left mine clear coated silver but custom colored anodizing can also be done..
PIC 1 ASP idler pulley with stock bolt cap
PIC 2 Stock pulley and ASP pulley
PIC 3 Install pulley
BTW, this is a 10 minute install or Re/Re.. It is that easy!
Cost $125.00 for a one off but should come down as more order..
Pictures on in this thread link..
https://mbworld.org/forums/w211-amg/...ed-me-big.html
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
thanks for your help...and your innovative thinking!
Any update on this?
