SL55/63/65/R230 AMG: HELP: HRE weird clicking sound
2003 SL55, 2010 C63
The weather is getting better and better here so I decided to change out my OEM rims for the 547R I bought. When I test drove the car in the garage I heard some kind of clicking noise from both the front wheels during acceleration and braking. If I accelerate really slow then there's no noise. I tried to check the tire pressure but it's really hard to get a correct pressure without leaking air. I'm thinking the rivets might be loose but can't find a thin wall 9mm socket to work on it, either. Any opinion is appreciated. Thanks.
2003 SL55, 2010 C63
I'm using the ones from my OEM rims. Where can I find the taper-seat lugbolts? Only the front wheels are making the clicking sound and I made sure they're at 100ft/lb torque a couple times.
SL55, CL55, Range Rover, Lexus LX470
I had a similar issue before, turned out that my lug bolts were too long. Had to order a shorter set of lug bolts to fit my wheel.
Bro to be honest, I cannot remember the length size, however you should contact the wheel manufacturer and request shorter ones, you need to ensure a correct seat fitting for your wheel as well or they will loosen up on you as you drive, that happened to me also. There must be a wheel shop in your area that specializes in wheels that could have a set readily available for you. As far as you driving, you will be OK for a minute, but that noise would agitate the hell out of me.
Another option is to do what I did. On my SL I reversed the set up, now I have studs threaded into the hub, instead of lug studs I have nuts. Ever since my wheel lugs came loose while driving 80 plus on the interstate in GA, I got paranoid about that.
2003 SL55, 2010 C63
Any reputable shop should be able to do the job, it only cost me a $100 to get it done. All that it entails is having studs threaded into the already existing holes of the hub were your studs screw into. When you put after market wheels on your car, you cannot go with the OEM studs Bro, it has to be a stud for that wheel. Occasionally you can interchange studs from wheel to wheel, but it would be ill advised. The best thing to do is have a set sent with the wheels when you purchase new wheels, that way you know they fit that particular wheel. Also find out your offset before ordering new studs, I believe that makes a difference as well, especially if you have a low offset like 20mm or so. Google your custom wheel shops. If you prefer, PM me with the specifics and I can get you squared away here with custom wheel shop. Better yet here's the link: http://www.customwheelsboutique.com/
2003 SL55, 2010 C63
you have to know the right ball or cone seat bolts. you have to measure the stud lengths and find out what you need with those wheels.
You probibly have a combination of both problems. I would say to go to a wheel dealer and let them figure it out.
2003 SL55, 2010 C63
I found that HRE normally uses cone seat bolts and the length on my OEM bolts are probably too long, too. I just ordered some Gorilla 17018 with one day shipping from Amazon so hopefully they'll get here on Wednesday. Thanks to everyone posted, you guys are always a good help.
I have good news for you, I spoke to my guy here at the custom shop and he has the proper studs for you in stock. All you need to do is call him and tell him what type of wheel you have and your problems will be solved. PM sent to you with contact info if you would rather speak to me first.
Econobox
Hello Guys,
The offered solutions sound like good possibilities. If you could, please give me a ring to let me know if these worked and to let me know exactly what you found.
MY information is listed below with my direct line.
2003 SL55, 2010 C63
Glad to know HRE has someone on our site to help. I have a question for you. When I tried to put air in my tires today, the hole seems too short to get the air in. Is there an easy way to do this? Thanks.
2003 SL55, 2010 C63
2012 C63 Coupe P31
Also, you are correct in that your lugs are too long and you need conical lugs. Stick your stock bolts into your stock wheels and measure the threads that sticks pass the face. Then measure your HRE wheel hole thickness from the seat of the cone to the face. Add the two together and then you got your thread length.
2003 SL55, 2010 C63
Sure man! Thanks.
Nice. Looks like I'll be heading to Autozone the first thing in the morning then. Got any picture of the prelude?
You need to get a valve stem extender, which can be purchased at Autozone for $4 for a set of 4. All you need is one though as you just screw it on and fill the tire and remove. The HRE valve stem is too close to the face and won't let you put the air nozzle on. HRE usually includes them with the rims unless you got them from someone.
2003 SL55, 2010 C63
Got the Gorilla lug bolts today and just installed them to 100 ft/lb torque. I measured the length of the bolts and both the Gorilla and OEM have exactly the same length. It fixed most of the noise and shaking (cone shape instead of ball seat); however, when I brake hard I can still hear a tiny bit of clicking coming from the front wheels. Anyone has any idea? Gorilla 17018 are used by a lot of people with HRE wheels and were the shortest I could find. I'm thinking maybe it's caused by the rivets not tightened enough but I can't find 9mm socket with thin enough wall to tighten them.
Econobox
It sounds like you just simply need one of our valve stem extensions. It'll give you about an extra 3/4". Give me a ring and I will send you one at $0.
2003 SL55, 2010 C63
After I changed the bolts I could still hear some clicking so I bought a 12pt 8mm socket just to make sure all the rivets are secured. On one of the front wheel about 1/3 of the rivets were less than 10 ft/lb torque. I tightened all rivets on all four wheels to 25ft/lb torque which is recommended from HRE and now I have absolutely no clicking sound at all.
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Glad to hear you fix the problem.
