SL55/63/65/R230 AMG: If you own a 600/65 V12TT get the "Latest" SPEEDRIVEN TCU
Old Apr 21, 2010 | 07:05 AM
DCMETRO22Z's Avatar
E320
Originally Posted by MarkoCL65
They were manufacturing those intercoolers for VRP at one time but are now selling their product directly.
OK... Now things are clear. That guy Marcin will bring some wonders in the futur...
I can't wait for him to put his magical hands on a 65 BS. bye bye Veyron !!!!
Old Apr 21, 2010 | 10:54 AM
Sunir's Avatar
SL55 AMG
Marcin is to Mercedes what guys like Clapton and Hendricks were to Rock n Roll!!!
maybe he'll chyme in and tell us what he will do for us SL55 guys...I've spoken with him before and he really likes the supercharged V8 platform
Old Apr 21, 2010 | 04:22 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Originally Posted by Thericker
Re-read my OP slowly, the 1st 800 rpm's in ANY gear are totally neutered in STOCK form IE the TCU/ESP nanny's pull the plug on the TQ output until AFTER those initial 800 rpm's in power band of ALL gears, so after TCU has ALL TQ limiters lifted every gear has found NEW untapped HP/TQ from 0-800 RPM's. Beyond that everything is improved vs stock...
That's my understanding of it anyway, Marcin will have to chime in as he his far better versed than I.
PS..No lie it actually feels like I gained more than the ECU tune, because these power gains are not just @ peak levels in RPM band but thru-out ANY/EVERY gear from 0-800 rpm's. It gives the car an entire new balance/aggressive nature like it lost 100's of lbs not kidding... @ 1st I asked Marcin if I was just imagining it, the gains are so impressive it's a shockingly different vehicle POST TCU mod...
A couple of questions regarding this:
- Based on what you described, seems like the benefit of removing the torque limiters would only be beneficial in 1st gear since every other gear change after 1st will likely stay above the 800 rpm range
- Is there anyway to firm-up and/or speed the shifts through a TCU tune or would it have to be done in hardware?
Old Apr 21, 2010 | 04:35 PM
Benz-O-Rama's Avatar
Mo,
I understand it as the FIRST 800 RPM of any gear, after gear change.
Old Apr 21, 2010 | 04:53 PM
Sunir's Avatar
SL55 AMG
I talked to Marcin today for a while ...he clarified this for me...
1) shifts are not harder but rather more efficient, using power in the band on each gear change
2) there is no increase in power or torque however since each change is missing the factory "hesitation" it feels crisper and better and ultimately will increase powertrain utilization efficiency through the gear range/powerband...but you still make the same power and torque
3) v12TT benefit most because they rev to 5700 vs close to 6500 for the 55k, the drop in RPM is greater on the v12TT as well
4) A TCU upgrade for the 55K will eventually be made available. The ECU and TCU for the V12TT and 55K are remarkably similar; so the TCU upgrade for the 55K will not be very difficult to sort out - and will have the same advantages as the v12TT TCU upgrade. This TCU upgrade does not have any relationship with ECU tuning with the exception of IF THE TUNING TELLS THE ECU TO CHANGE THE FACTORY SHIFT POINTS...if such is the case then that information is needed for the TCU tune.
Hope the above helps
Old Apr 21, 2010 | 04:57 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by Benz-O-Rama
Mo,
Correct... My bad I should've been more succinct the 0-800 rpm description was reiterated to try & explain where the NEW power lives. Don't mean literally the gear change @ 2nd-3rd etc go back to 0 rpm's lol... Just that the 1st 800 rpms in ANY/EVERY GEAR were previously SEVERELY TQ limited, now they're not.
Yes, it's power the car always had just never unlocked before in those RPM's.
Old Apr 21, 2010 | 09:52 PM
  #32
Did you happen to get rev-matched downshifts (Throttle blipping) with this?
Old Apr 22, 2010 | 01:07 AM
  #33
Thericker's Avatar
V12-Biturbo
LoL yeah it's called your right foot flick-gas, while hitting steering wheel down shift button
Old Apr 22, 2010 | 03:22 AM
  #34
Dsmed's Avatar
ML320cdi, F250dsl.
Gonna have to dig into that a bit. If enough interest is expressed we might try see if its possible. FYI, if a car has throttle blipping its there all the time, might get annoying on a car that a daily driver. Might be cool for a week or two but think about it long term.
Old Apr 22, 2010 | 04:56 AM
  #35
backdoc7's Avatar
C300, Viper RT/10, E55
But wouldn't the intensity of it be dependent on the downshift rpm's... what i mean is, if you coming off a fwy and not downshifting at all (coasting), you don't really feel the trans downshifting... would you still feel it blipping? as opposed to coming of the fwy in a high rpm state and grabbing lower gears... then i can see it blipping aggressively?..
Old Apr 22, 2010 | 07:42 AM
  #36
Marcin,
The few cars that I've driven with this featue only did it when the car was in it's version of manual/manumatic mode. When left in "D", either it didn't happen, or I just didn't notice it. It was only when the car was shifted manually.
Hope this helps.
Oh, and can you PM me pricing? Thanks!
Old Apr 22, 2010 | 08:08 AM
  #37
cal1's Avatar
SL55, ML500 & Acura TL
Thanks Sunir for getting the scoop on this for us 55k guys. I will be watching this close although I just recently told my wife I was all done with mods. I say stupid sh.. sometimes.
Old Apr 22, 2010 | 03:52 PM
  #38
URnext's Avatar
SL55 AMG
Sean, congrats on the new mod.
Hopefully the TCU comes out soon for the 55's and the throttle blipping will be frigin bad ***. I will sign up just to get throttle blipping.
Old Apr 22, 2010 | 04:38 PM
  #39
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Sunir and Sean...maybe you can shed some light on this...I have the Kleeman TCU and per their admission this mod is really for the non-AMG V12's and that I would not really feel much of a difference as opposed to the TCU in the SL600.
Does this hold true for this TCU upgrade also, since the AMG TCU is already pretty aggressive?
Old Apr 22, 2010 | 05:01 PM
  #40
Sunir's Avatar
SL55 AMG
Jon I'm not sure as I have not driven a car with a TCU upgrade I don't think, or not to my knowledge of the MB cars I've driven. This said I do think the factory TCU programming on AMG cars is more aggressive - so in that case the delta of feel with said TCU upgrade may be larger on a non amg car compared to that of an amg car. Just basing upon heory, not practical evidence. on the v12TT platform there are 600 (non amg) and 65 (amg) however in the case of the 55 platform - Marcin is creating the 55K TCU for the 55K cars (E, CL, CLS, G, S, SL) all of which are amg cars.
Old Apr 22, 2010 | 05:39 PM
  #41
Thericker's Avatar
V12-Biturbo
Yes I'd guess the perf increase would be a bit more in a 600 due to AMG speed shift prog in 65 vs reg 600 NON AMG version, though the TQ limiters are just as restrictive accross the board & MAIN REASON for huge SOTP increase in either model 600/65. IE Marko has an 06 CL65 re-read his post
I just got mine installed yesterday. Holy wow!! I'll give a full write up when I have a little more time. Here's the sequence of events:
5:04 pm Marcin Installs SpeeDriven TCU
5:06 pm I'm driving in traffic and finally get onto the highway
5:07 pm I'm on the phone with the local drag strip inquiring about their schedule
5:18 pm I've burned a quarter tank of gas
This is the fastest my car has ever been. I now have both the SpeeDriven ECU and TCU mod. I'm going to the drag strip Thursday. I expect to easily better my 10.72
Old Apr 23, 2010 | 03:19 AM
  #42
Dsmed's Avatar
ML320cdi, F250dsl.
Well we made it out to the dragstrip with Marko's CL tonight.
Track prep surprisingly sucked, usually GLD has good prep. He got one clean pass without tire spin where he left the line of idle. With a 1.7 60foot the CL went 10.70@134.3mph.
I'll upload a vid to youtube tomorrow and you'll see what I mean by not hooking. Car would rip loose 70-80 feet out and being that the car is without a cage, we got to make passes count. So out of 5 passes one fairly clean one before we got the boot.
Might hit another track this Sunday in hopes of better prep.
Old Apr 23, 2010 | 03:28 AM
  #43
Dsmed's Avatar
ML320cdi, F250dsl.
Marcin,
Hope this helps.
Well I guess my problem is that the very first thing I do when I get in any car after turning the key on is, set trans to M (if it has it) and disable traction. Force of habit I guess.
No promises about the throttle blipping, but we'll deffinetly look into it.
Old Apr 23, 2010 | 05:02 AM
  #44
Thericker's Avatar
V12-Biturbo
Well done man!!!
So previous to adding your ECU/TCU, Marko's CL65 used to run
06' CL65 White/Ash 10.73@130.86
You gained friggin 3.5 mph in the 1/4 ALL that spinning & you still dropped the ET to flat 10.70
Def a 10.50- in her w/1.60 60'
Old Apr 23, 2010 | 09:55 AM
  #45
Marcin or Marko....
What was this car's previous highest trap? I know that the 10.73 run had a trap of 130, but was that the previous highest trap, regardless of E.T.? I know that was the previous lowest ET, but I'm really only interested in the car's highest trap, prior to the TCU. Also, what were the track conditions (DA)for both? Was the air much better last night?
If you gained 3.x MPH over the previous highest trap speed, in similar DA, I'd have to say that the TCU upgrade was a success!
Seriously considering this......
Old Apr 23, 2010 | 01:03 PM
  #46
Dsmed's Avatar
ML320cdi, F250dsl.
Honestly don't know what the DA was last night. Passes were done at around 8:45-9pm @ greatlakesdragaway. Prior to this his fatest pass both in ET and MPH was at MIR 130mph. We did not add ice to tank last night. At MIR ice was used. Ecu and TCU have been flashed since than.
Old Apr 23, 2010 | 02:55 PM
  #47
cal1's Avatar
Looks like DA was good last night at Great Lakes. According to Dragtimes the DA was -558 @ 8:53 PM.
Old Apr 23, 2010 | 08:05 PM
  #48
Hammer Down's Avatar
2015 E63S, 2018 E63S
Do the firmer shifts only come in manual and sport mode? I'd like the ability to throw it into comfort when I don't want to snap my wife's head clean off her shoulders.
If she has life insurance then its all good
Old Apr 23, 2010 | 08:16 PM
  #49
these TCU mods are coming for you 55k guys too
Sweet!
Old Apr 23, 2010 | 08:23 PM
  #50
Thericker's Avatar
V12-Biturbo
Originally Posted by Hammer Down
Sweet!
I knew eventually we'd entice you to the Darksideof modding
