SL55/63/65/R230 AMG: On or Off...
Or when it's off does that mean it's off. This is the red light on my air con
button. Yesterday I got cool air with it both on and off.
Any help would be grateful, or are you as confused as me
It seems that the A/C is on ALL the time if the blower motor is on. My car blows cool air with the A/C light ON OR OFF. The only way for me to turn the compressor off is to turn the whole system off.
I can't find a way to get ambient air through the vents without the A/C being on.
I CANT STAND HOW YOU CANT RUN THE AC ON HIGH WITH THE TOP DOWN, I NEED TO FIND A WAY TO TRICK THE CAR SO IT THINKS THE TOP IS ALWAYS UP
like to turn it off, gives me a bit extra power as well. I think MB handbooks
are the most difficult to understand!
But as I said with light on or offI can still feel refrigerated air.
Thanks guys anyway!
Thanks guys anyway!
I think you are feeling the air from the chilled center console compartment ... The air conditioning unit remains on at all times to keep that center console cool for your cigars, flat sandwhich's, gum, condom's, Etc... The cold air that you are feeling is just residual air from that. No air should leave the vent when the 0 button has a red led showing and when the ac off button is on the air that is coming from the vents is from the fans. If you are in the UK rub your left leg up against the center console next time you go for a drive and you will see what i am talking about.
Hope this helps
Well guys it seems we all have problems with this, I don't have a refrigerated
center console, i did on my SL55 but yesterday it was an normal day, set
my temp at 20 and drove with the a/c rest button lit up, certainly chilled air
was coming from the vents, then I turned the a/c rest button off, no light.
Waited 10 minutes driving around 70 and still chilled air came out.
HELP!
The A/C has to be turned off for at least a couple minutes for the Intake Temps (IAT's) to drop enough for the ECU to give full power and not pull timing when you get on it.
Off topic...sorry
Off topic...sorry
Then you say .. so when you punch it in... punch in what, the a/c button so
it's on or off the light I mean? That's the whole point.
In my SL55 I could turn it off easily, and always did when racing.
You say it has to be off for at least 2 minutes, trouble is I don't know when it is, off I mean.
Disconnect the A/C clutch plug and put a meter on it. Turn the A/C off in the car. If you're not getting voltage, then it's your compressor or clutch. If you're still getting voltage, then you have some other issue(s).
You may have to have the engine running to do this test, don't know it the HVAC unit will power the A/C clutch with the engine off (and key in RUN).
I own a Scanguage II. It shows me my boost in PSI, My Intake Temps (after the intercooler), Timing, Oil temps, coolant temps et et et
Our cars have an air to water intercooler. It takes a few minutes to cool down the intake charge when you have run the car hard or you have been idling in traffic OR running you’re A/C system.
Just turning off the A/C in our Supercharged 55k engines doesn't work the same as a naturally aspirated car.
What I mean by "punch it" is go to full throttle.
throttle on my nat *** 63 turn the a/c off. It's a bit drastic having to drive everywhere at full chat though, there must be another way, but thanks
anyway.
But I'm still not sure what the answer was to the original question:
On a U.S. SL55 that has an A/C/ button labeled "A/C" and with the word "Off" in smaller letters off to the left, is the A/C on or off when the red light is on. On or off only please.
