SL55/63/65/R230 AMG: Rattle - Gas tank
HHow do you remove the grey plastic covers that cover the hinge mechanism?
Please contact me I have a loose baffle i need your help to fix it
S
S
Hi I got the dreaded faulty baffler and was wondering where u r located
He had two hesitations I want to share here fwiw:
1- a spring which allows the plate some swinging (don’t know if it does) could eventually make remaining spot welds snap. His plate, by the way, snapped behind its spot weld, not on it. It was the plate itself that failed.
2- liters of swaying fluid could pose a hefty strain on your fix. Think of some jerk accelerating and stopping a car while at the passenger seat you’re trying to keep still a few big buckets filled with liquid. Will the plastic arm of the sender unit cope with those reciproting forces, in the end? (The same can be said of the L shaped bracket and the rod of course, seeing that failing metal caused the problem in the first place).
All in all, a solution without drilling and leaving the sender alone has its elegance.
QUOTE=Desert Dog;7900106]OK, So I have not gotten time to take a look at the gas tank sending unit and baffle. Will probably try the spring fix described here, but would love to get feedback from those that have done it: Do you think there is enough room to compress some fuel cell foam, insert through sending unit opening, and position so that it wedges the baffle in place? I don't know if the foam could be compressed small enough, or if you could get a big enough piece to do any good.[/QUOTE]
Bassie.
Still investigating with some garage of doing either the tank exchange or "spring fix".
