SL55/63/65/R230 AMG: Replaced trunk struts!
Old Aug 27, 2019 | 11:36 AM
  #51
captex's Avatar
2003 SL 500
Hello, Karl. On SL500 tubular strut, how do you proceed after strut replaced to close the top back down.
Old Aug 28, 2019 | 02:15 PM
  #52
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by solomed
Anyone ever try the "upgraded" Stabilus struts instead of the exact OEM replacement? Found both here:
http://www.autopartsdeal.com/catalog...t+Lift+Support
I used those before as well.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 18, 2020 | 07:49 PM
  #53
HopefullyE63's Avatar
SL55 CL600 and 335D (rip flood) 325ci
I just bought these Stabilus units and am super happy. Don't be afraid to do this it is SUPER easy. Small flat screwdriver. Fixed a daily annoyance with the car for about $80 shipped
Old Jul 31, 2021 | 06:12 PM
  #54
58yearoldinSL55's Avatar
2004 sl55, 2005 GX470, 2004 XJ8
HELP!! I'm Stuck - solution found
When using the actual key inserted into the trunk lid to disconnect from the main supports, I had forgotten to remove the metal key from the trunk. If you do so, the entire roof system is frozen!
Old Mar 28, 2023 | 03:11 PM
  #55
Blaz's Avatar
CLS 55 2006, SL 500 2006, CL 500 2013
Hi, any chance to say, how should be replacement done, pls?
I have got this small gas strut for rear shelf...there is a tension cable...
Thank You
Old Mar 28, 2023 | 05:10 PM
  #56
Thank You
Hi
I did this a year ago, but it was pretty simple. The biggest trick was to decide just when in the 'convertible top opening process' to turn the key OFF to 'freeze' the various moving parts so that you could access the smallest strut. The other three were pretty easy, it was just the small one that took some good timing. Don't forget that the system will time you out after a certain period of time if you stop the process by turning off the key - if you are delayed, just tap the key on and off so that the timer resets and gives you another period of time to finish the install.
