SL55/63/65/R230 AMG: Steering wheel controlled ELM now available!!
Old Nov 1, 2010 | 08:03 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
As some or most of you know I've worked in conjunction with Loweringmodule.com to help bring a new style of lowering module to the Mercedes market. I'm happy to report the new lowering module called the "M1" is now available!
Overview:
This new style of ELM lets you control and adjust your ride right from the convince of your steering wheel. While displaying your right high settings on your instrument cluster. The M1 creates a new scroll though menu that is easily accessed though a simple prompt. The M1 brings a level of convenience, and stealth to the lowering module market. No more remotes, no more laptops to adjust your ride hight.
You can make adjustments for the front and rear of the car independently. If you desire the front to be lower than the back you can easily call up a setting to meet your ride hight needs. If you need want your car slammed for a car show. It can all be done with some simple touching of the steering wheel. Same goes if you desire your car to be in 4x4 mode for those construction zones that seem to be popping up in random locations.
The lowering module is available though loweringmodule.com the retail price is $1695. However I have worked out a deal with loweringmodule.com to offer you the M1 at $1495 with a coupon code MBH-FHF
Cost: $1695
MBH Motorsports special pricing is $1495*
* special pricing requires the use of MBH Motorsports coupon code MBH-FHF... Please Note: The code is case sensitive
To order the M1 please go here and enter coupon code MBH-FHF to save $200
NOTE: this works with all Airmatic and ABC Mercedes. EXCEPT 2003 SL's
http://www.loweringmodule.com/index....ingmodule.html
Video Overview/Demo
http://www.youtube.com/watch?v=44mjCMuLqZI
Old Nov 1, 2010 | 08:30 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
No 03 SL??? WHY???
Old Nov 1, 2010 | 08:58 PM
Thericker's Avatar
V12-Biturbo
Very KOOL man..
Old Nov 1, 2010 | 09:34 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
How is the install? Plug and play or cut and solder?
Old Nov 1, 2010 | 11:23 PM
Plug and play. It installs much like anyother ELM.
As for the 03 SL, I hear its a CAN system issue.
Old Nov 1, 2010 | 11:38 PM
CHP_H8_ME's Avatar
'03 SL55. Wife drives '06 SL500 and Range Rover Evoque
Nooooooooo! of course I have an '03....the CAN system? Is there some VIN # break or maybe some early '04 have the same system?
Old Nov 1, 2010 | 11:42 PM
There every well might be a VIN # thing going on. I will look into it. When I heard it wouldn't work on 03's I was bummed out. I will find out for sure.
Old Nov 1, 2010 | 11:51 PM
DoctorJeff's Avatar
That's some cool stuff... I notice in your video comments you mention you'll be shooting another video showing the ride heights. Could you also show the install process? BTW, what do you set the factory suspension at (no lights/lights) and is it even functional? Sorry if I missed that in the video.
Old Nov 1, 2010 | 11:52 PM
CHP_H8_ME's Avatar
Thanks. Keep us posted, as you and I know, there are a boat load of '03's out there!
Old Nov 18, 2010 | 02:40 PM
CHP_H8_ME's Avatar
Any new news?
Old Nov 18, 2010 | 04:22 PM
2003 SL55, 2010 C63
Originally Posted by CHP_H8_ME
Any new news?
+1
Old Nov 18, 2010 | 08:15 PM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
this would come out the month after I install the v3......anyone interested in v3 and a touchpad mini pc (the package that renntech sells)
Old Nov 20, 2010 | 03:00 PM
OUTCAST's Avatar
SLK55AMG, SL600
Very slick!
Old Nov 30, 2010 | 12:00 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
The "M1" ELM sounds like an amazing product. To control and adjust the ride height from the convenience of your steering wheel is the way the SL should have came stock. I'll probably be adding this mod in the near future!
Old Nov 30, 2010 | 01:54 PM
Sunir's Avatar
SL55 AMG
sounds SWEEEETTT! But bummed that '03 SL55 gets the shaft on this one
Old Jan 18, 2011 | 04:46 PM
masada's Avatar
"Returns to factory ride height at highway speeds"
Any way to override this?
Old Feb 22, 2011 | 04:37 PM
goalie_k's Avatar
2012 GL350
Yes they can configure it to return to stock height at any speed you request.
Old Mar 3, 2011 | 08:53 AM
Fasthound's Avatar
2007 SL55
Has anyone on here actually purchased and installed this yet in their personal SL??
Old Mar 3, 2011 | 10:14 AM
I guess I have a bias, but I'll give an honest review after living with the M1 for some time. First off, If a product doesn't work as advertised, I don't want anything to do with it.
This ELM is the last thing I think about. I set the ride hight and forget about it. It never does something I don't want it to do. With +/- totaling 17 settings. Including slammed, stock, 4x4 and anything in between. I keep my SL55 at -6 front and -6 rear. No need to ride around on the bump stops. However if thats your thing, you can do it. I find that at the -6 setting you can get a fantastic look and with a quick touch of the raise the car button on your center console. You can clear those pesky speed bumps in the parking lot. Without scraping your front end or under side of your car.
I do alot of driving in my SL. Lately I've been wanting comfort when bombing around town. So, I've found myself leaving the car at -6 and driving around with the factory lift button on. Then when I pull into a place, I shut the factory lift button off and the car gets slammed.
I run 20" HRE's and have no issues with rubbing at any of the ride heights.
The best way I can describe the M1 is... It's kind of like a Sleep Number bed you see on TV. There is a setting or combination of settings for just about everyone. So its a matter of finding yours. Do you desire looks, comfort, or a combination of the two? You can Independently set the front and rear to any setting. If you like the front to be lower than the rear or vice versa, you can do it.
Its also super stealth. Some times folks swap cars, because they need to borrow a friend's truck or something for the day. You can put it back to stock with few touches of the buttons. You won't have to worry about your buddy messing up your car over a speed bump.
One thing I need to try is the is how the M1 settings are married to set keys. For the longest time I could not find my spare key. Then it turned up durring a recent house cleaning. I'll test it out today. The capabilities of the M1 ELM claim that the ride hight settings are Key specific. Meaning, if your wife has a set ride hight she likes that differs from yours. The key she has will overide your setting and convert to hers. This means, If she's going shopping in your car, you don't have to set the car up for her so she is comfortable. Thats assuming they don't know how to use the ELM in the first place.
Another nice note you don't need a PC tablets, Laptops or anything like that in your car to use the device. One less thing in your car for a thief to steel. We carry the complete line of loweringmodule.com's ELM. They are also available though Speedriven, ACG, and of course Dyno-Comp. For anyone in the Arizona area that would like to see a live demo of the M1 contact Dyno-Comp. We have V2 ELM's with remote, M1's, Carlsson ELMs, and others. Alot of these are in stock at Dyno-Comp and loweringmodule.com
Old Mar 3, 2011 | 11:25 AM
Havoc's Avatar
Great write up and thanks for you're honest review.
I like what the M1 has to offer and it seems to be a very unique mod. I don't have it yet, but I'm very interested in it and it's on my wish list for a future mod.
Old Mar 3, 2011 | 01:29 PM
NEMES1S's Avatar
This sounds like a great system, I assume install is fairly straightforward on sl's?
Old Mar 3, 2011 | 11:18 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
+1 on the install process.
Old Mar 11, 2011 | 03:43 AM
Yosheego's Avatar
2011 E550
Wow that's awesome! I think i will get these very soon here on my 2011 w212! =D
Old Apr 9, 2011 | 03:15 PM
RNSL65's Avatar
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
4 wheel alignment needed when changing ridehight
I just want to information you, that when you have decided for a particular ridehight of your car, you need to do a 4 wheel alignment of your car! So you can't just change ridehight of your choice every day as pleased, without the wheel alignment.
I did the that mistake, and it coated a set of tires!!!
Old Jan 24, 2012 | 12:51 AM
euphoriaDSM's Avatar
SL65 AMG
Any updates on M2 and if it will solve this:
