SL55/63/65/R230 AMG: What are the advantages/disadvantages between the SL55 2003 and 2005+??
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
Hi guys,
I am somewhat knowledgeable about the E55 W211 since I currently own one. However, I don't know much about the SL55 chasis and
I'm currently in the market for a SL55. What are the advantages/disadvantages about the older year (2003-04 and 2005 and newer)? I know that the NAV is different on the 05+. I also heard that there are a lot of problems with the suspension on the 03. Also, how much is a 05+ runs for? Please chime in.......
Thank you!
Thank you!
SAME ENGINE.. im sure you're already know that...
abc instead of airmatic
nav is update with bluetooth
lights and cosmetic are slight change from 03 to 05.
4drs to 2dr.? what happen? devorse?
08 CLS63, Honda Accord, 04 911
Nothing really wrong with an 03 at all..but in general car talk its a first year model so some buyers like to wait until the 2nd year of a Model lineup..
As with the W211 go with the latest model in your budget or the right choice with warranty, miles, mods ( if wanted) , etc and youll be fine.
Several MB's Superperformance MK III Cobra
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Quote:
Originally Posted by jmf003
A bigger throttle body also got added somewhere along the way but I don't recall which year.
It was 2006 or 2007.
__________________
Lou K
[QUOTE]
Believe power also went up from 493 horses to 508, and torque from 516 lb-ft to 535...
Brgds
__________________
Lou K
[QUOTE]
Brgds
[QUOTE=OK55;4444654]Quote:
__________________
Lou K
Brgds
It was 2006 and the horsepower did increase due to the throttle body and minor supercharger tweaks. A little known fact is that some of the early 2003's also had the larger throttle bodies that were subsequently replaced with the smaller TB's until the 2006 model year. Also the SC clutch pack was changed in 2006 not in '05.
__________________
Lou K
Brgds
2003 SL55, 1999 Lexus LS400
[QUOTE=lkirchner;4444690]
Is there an easy way to tell which throttle body a 2003 has?
For what it is worth, 03 was the first year for the R230 in the U.S. O2 was the first year in Europe so MB did have a bit of time to work out a few bugs.
'03 SL55. Wife drives '06 SL500 and Range Rover Evoque
What's the big difference between ABC and Airmatic? Even the 2003-2004 cars I see say "ABC" on the suspension button.
Didn't the 2003 also have a horrible "cat ****" order problem? Or was that just the designo cars?
