SL55/63/65/R230 AMG: SRS warning light ON
Old Apr 27, 2011 | 03:21 AM
friehat's Avatar
2004 sl55 amg
Suddenly, the SRS warning light went ON for no obvious reason. Any thought about this issue and how to fix it.
Old Apr 27, 2011 | 12:32 PM
cal1's Avatar
SL55, ML500 & Acura TL
Maybe this will help: https://mbworld.org/forums/sl55-amg-...lfunction.html
If not, post back and someone should be able to help out. You might find more on this as well through the search function.
Old Apr 27, 2011 | 04:32 PM
aluthman's Avatar
2003 SL55 AMG
Most common cause from what I have read is either a high or low resistance from the connectors under each seat. Easy DIY fix, but you have to have light cleared with SDS. If you don't have access to one, that means a trip to the dealer.
