SL55/63/65/R230 AMG: ABC Sport button won't light up...was it an option on 2004?
If it doesn't lit up, than this could be due to two reasons:
A) LED broken
B) ABC broken
You'll need to take it to the dealer to find out.
go 60-70mph in a straight line. nudge just a bit (less than an inch) the steering wheel in either direction and feel how the body responds (you will feel front and then back end "settle").
press the button
repeat the nudging. feel it significantly tighter/faster or looser?
if no difference- your abc modes are not working properly. if difference- the led on the abc sport button is out.
Can one of you check something? Does your ABC light come on for a split second when you start the car (for instance, the 2 LED suspension lights come on for a split second when car is started....I assume almost like a self check). Also, if you turn on the ABC while driving and then turn car off (with ABC still on)....will it start in ABC Sport mode the next time you turn the car on....or does it start in normal mode again? Thanks.
