SL55/63/65/R230 AMG: Help!!! I need a fuse chart for my 2006 SL65
Old Jul 19, 2011 | 02:58 AM
Chasen9's Avatar
2006 Mercedes-Benz SL65
It's supposed to be in the trunk with the tool kit, but it's gone. I would assume its a standard fuse chart similar with other 2006 SLs. In particular, I'm trying to find where the fuse that links to the MB Bluetooth Puck in the console would be located. My bluetooth puck functions fine (blue programming light lights up in other new MBs, so in my car it's not getting power). Can anyone help me by e-mailing a copy of the chart? I would be in your debt! Thanks - Steve chasen9@msn.com
Old Jul 19, 2011 | 04:03 AM
EXECMALIBU's Avatar
SL65, 427 COBRA (CSX-3127)73 911S, 246GTS (DINO SPYDER), CORNICHE,1962 PORSCHE TWIN GRILLE ROADSTER+
NONE of the fuse charts are CORRECT!! Took dealer an hour to find relay/fuse on LTP..
The fuse chart in the tool kit that comes with ALL the AMG cars is WRONG and is for a 2002 SL500! Even the fuse chart out of a brand new SL63 at the dealer had the same fuse chart dated 2002.
It took the tech at the dealer about an hour to find the exact location of the relay for the Low Temp Water Pump. The location on their Startek system showed a schematic with 5 relays behind the Passenger seat. Problem was my car has 7 relays in a different layout. The tech had to call MBUSA with my SL65 VIN for the specific layout and location of the fuses/relays.
Old Jul 19, 2011 | 04:09 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Check the search function here...
I think there was one here not too long ago....
Old Jul 19, 2011 | 11:50 AM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
I would assume your car does not have the required UHI module (which powers the puck). If the UHI was dead (fuse blown), you would have no sound from your system at all.
You did not mention if you have ever seen it work in this car....
Old Jul 19, 2011 | 05:28 PM
jmf003's Avatar
'03 SL55
Yep! It's here: https://mbworld.org/forums/4505546-post9.html
Old Jul 19, 2011 | 05:50 PM
EXECMALIBU's Avatar
That is the same Fuse Chart dated December 3, 2001 and it is WRONG for the R230 AMGs
That is the same fuse chart that is in all of the Tool Kits all the way to the 2010 SL63s! I know because on the showroom floor I checked a new SL63 about a year ago looking for an updated AMG Fuse chart but it still had the same exact fuse chart that was dated December 3, 2001 (I remembered 2002)...
December 2001 was long before our US version R230s especially the AMGs were built and that chart is WRONG!
