SL55/63/65/R230 AMG: Trunk soft close question
I disasemmbled the latch assembly and plugged with epoxy all the pellets (a common problem), although mine did not appear to leak anyway. the black and the white piston assemblies appear in good shape. Not cracked or anything.
The soft close works well, just the hissing is there.
My question is - after your soft close your trunk- do you hear a hiss? For how long? Just trying to determine if I have a problem or all is good.
Thank you
Just went out and opened/closed the trunk a few times. When opening, definitely hear a hiss, the sound of air in the pistons I guess. When closing, there is NO hiss at all - after the trunk latches, I can hear what sounds like the electronic mechanism closing for about a second, then about two seconds of silence, then that electronic sound again for a few seconds. But no hiss like when the trunk is opened. Hard to describe the sounds; hope that helps.
Bob
You know what they say.. "If it aint broke, Don't fix it"
But, if it's hissing when closing> you may have a problem.
It could be anything from a leak in the pump, in a hose, hose fitting, latch mechanism, etc.
I can have it hiss when I have the assembly off the trunk and I can feel the air escaping from somewhere but can't pin point it... Now after I know it is not some kind of a blow off valve I will look for the problem using a stethoscope.
Ah.. The fun those cars provide...
using a stethoscope i found a tiny (barely visible) crack just behind one of the pellet plugs on the least visible plug outlet.
it was tiny and on the inside... you could not see it and the escaping air was getting bounced around so you could not pinpoint the source easily.
i epoxied it and no more hiss
so the moral is (i know, i know.. spare me) - if it hisses - you do have a hole/crack somewhere.
on related thoughts- looking at the design of the latch mechanism- what a cheap plastic piece of **** it is... not to mention the unfortunate design decision to plug the non-used air ports with pellets which might crack the port when the plastic gets a little old.
