SL55/63/65/R230 AMG: got my duel cold air intake SL55 engine
[quote=Iknownothing;
Where did you get the parts? this is a Needswings intake
[quote]=320 dreamer
800 cfm? was that on robs flow test? i thought it was 700 cfm ,,, you are right,, it was 698 to be exact.
[quote]=B R Are there any filters in that system?
yes run the video it tells you but yes, at the same location an stock.
hoodscoop : air inters through the hood then into a air box then through the filter then to the engine if there are small bends and the filters flow high and no interference then your good,,,example: the stock sl55 intake has lots of of interference and flows 515 cfm,
smooth tube w/free flowing filters like the needswings intake flows 700 cfm
200 cfm = an increase of about 2 lbs of boost and 3 to 5 tenths in the 1/4 mile.if you can get your IAT's no more than 10 to 15 degrees above ampient temp. you good,,as for mine they are 5 to 9 degrees above ampient,, as for filters (cone or any type if it is under the hood pulling hot air , your IAT are very high and you loose power not gain. jim
the air intake right up front where the cool air is, rather that putting K&N
cones under the bonnet/hood where the hot air is. Great stuff
The CROSSFIRE is vastly different (It doesn't share the Hydraulic Suspension "ABC" found on SL55/65/600/63 models, & takes up a lot of space needed to fit the NeedsWings CAI) Also it's a completely different car in terms of Hood, Under Hood, Grill, tollerences as the CROSSFIRE's Engine bay is made for a NON-Supercharged 5.4 liter motor vs Supercharged SL55 etc)
The air holes are very small in diameter due to Cooling/Plumbing hoses running thru air intake holes @ least on the SL65/600/55 models I've seen in person. & very difficult to run CAI up to MB grill as holes get very small IE less than 2" on Drivers side etc.
Les
From looking @ NeedsWings website, it shows only the front part of CAI, & not the Radiator run-thru scoop part? It appears to utilize old OEM factory ducting to just route to original openings, not showing the larger run-thru air scoops mated to outside Radiator. (maybe just not pictured?) As well the CFM is lowered on E55k model to
it outperforms OEM 600/65 in every way.. Don't wanna thread-JackLast edited by Thericker; Jan 19, 2012 at 06:21 PM.
Got any pix to post up yet ?
