SL55/63/65/R230 AMG: SL55 valve ticking noise??
Many thanks for any advice!
it is hard to tell without hearing it 1st hand, but i would say that the car has sat a while and was not driven much so it might have some carbon deposits which are easily treatable with some techron and spirited driving
I'd also check the oil and filter service history. Using a fleece filter and the 0-40 Mobil 1 can work wonders with engine noise, hence friction.
If the oil was filled from the bottom I'd check to make sure the copper ring was always replaced because some tech say it not only prevents leaks but helps with the lube package. Most dealers use 5-40, no biggie, they just get it in bulk so it is cheaper and more convenient.
0-40 is just better.
and since 2007 5w40 esp mobil 1 supersedes the 0w40 and is recommended for all mercedes vehicles requiring 0w40
Talk to Glyn abut oils and fluids various, please, he is the expert. I refer you to his threads.
There is a diesel oil for the 229.51 spec that is 5-40 M1; I recall the gas 5-40 M1 is recommended for certain engines only. AMGs with the 113K or the 12V engine, as a rule, use 0-40, thank you. I also use it in my G500 per my tech's recommendation. Try it you'll like it.
As far as the copper washer goes I am referring to information from the MCBA tech advisors. Glyn may have another informed opinion.
Could you post the 2007 MB communication?
Is there anyway I can easily check that its just carbon build up? Its a really clean car and I'd like to buy it, but I'm worried at the possibility of a more serious problem with the top-end of the engine. For example would the MB dealer be able to diagnose?
On my test drive the car had full power and there was no exhaust smoke.
Also, is Techron a fuel aditive?
Robert is correct, all injectors. Not oil related.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
But as said before, it's really hard to say without hearing the actualy sound.
