SL55/63/65/R230 AMG: Paranoia, SL65 reliability, ABC etc
Love the car, but like the rest have mentioned it's not the cheapest thing to maintain. I humor the dealer for my services so they don't argue warranty items. I've had a few things replaced under warranty as it is. I bought mine CPO with 3 years of MB warranty. I think it's getting close to paying for itself in the year and a half I've owned my sl65.
As far as repair cost, that's why I am intent on getting a "good warranty" if at all possible. Still shopping.
2) Price was good after depreciation - dealer dropped $ 7K or 10% from the price 3 years ago when I bought it.
3) The performance - fast and effortless
4) Versatility - hardtop convertible - very key
5) Great smooth ride for long trips..amazed that it gets 21mpg highway...
6) Solid service record with low miles - 26K, now 43K
Don't like navigation system, small trunk and that is about it........
Its a classic that requires no posing...........although, speaking of "ballers" I bought it a half hour before a NBA player that I saw afterwards at the dealer was going to!!
This subforum has a lot of content that is hard to filter for the info I need. So owner experience would be great.
Car Fax on the car will show anything major or under warranty.
Once you have the computer stored records and any documents/records that came with the car, that will tell you what to change/replace, etc......and when.....
I wouldn't spend money needlessly on fluid changes unless it needs to be done.....and records don't show anything related to that....
Depending on the mileage....a transmission service is good to do at 40K if it hasn't been done and also check the serpentine engine belt tensioner, as it may need replaced at 50K or a little less....check the same belt for any cracks also as it may need replaced.......
Test drive the car before handing over the cash.....even if you did before....
Do a deliberate FULL throttle test a few times to make sure it doesn't misfire....if it does, coil packs could be ready for replacement.....the misfires seem to typically occur only under FULL throttle.....
Use the paddle shifters to make sure all works smoothly in every mode C,S and manual....
Brake real hard a few times from 70mph+ to see how straight it stops and any unusual noises from pads/rotors - it should be quiet/smooth.....I had to replace my front rotors at 30K - $ 2,000 job...I also test drove a car where it had a real grinding bouncing type of feeling......
Make sure the car's ABC rises up and down before purchase as it is supposed to....operate all electronics, i.e. CD changer, radio, seats, internal rear trunk release switch, etc..check Distronic cruise - if equipped....lights, just everything operational......wipers......windows, etc...
Use steering wheel buttons to check on-board computer operation...
Test anything associated with the PSE air system, i.e. the massaging seats and automatic trunk soft close......struts for the trunk lid known to go bad soon.....
Check the glovebox to make sure the latch works....common repair adjustment issue.....
Operate the hardtop several times to make sure smoothly working....
Spring link bushings tend to go fast on these cars.....check to see if anything noted in records, etc....have them check them if possible before delivery....$ 750-$ 1K repair...I had them done on mine before delivery....
Check motor mounts - another weakness over time....
There was a service bulletin (TSB) on a creaking noise in the suspension when backing up real slow and turning the wheel either way - say out of a driveway....do that to see if all is quiet....$ 200 fix when it happens - lubrication issue, etc...
Spark plugs in the 65 recommended to be changed at 5 years old regardless of mileage according to the manual, etc...
Other than that......have a blast and you'll love this car!!!
Engine checked
Steering/suspension checked
Washed/detailed
Fuel injection system checked
Fuel system checked
Spark plug(s) replaced
Ignition coil(s) replaced
Electrical system checked
Engine/powertrain computer/module checked
Battery/charging system checked
Those two items were my most immediate concern.
Some of the fuel system checks may have had to do with misfires/CEL also as they were diagnosing to fix the situation, etc...
Coils are about $ 1,200 to $ 1,600 a piece and plugs can cost a bit, so good that stuff was replaced.......
Great you checked all this stuff with the PPI.......
I don't believe the V8 had many regular coil pack issues, if any....
Thanks again for the checklist abiazis.
