SL55/63/65/R230 AMG: Mystery Power
Old Jul 17, 2012 | 12:21 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Originally Posted by PDC
Checked Schrader valves at cool idle. DEFINITELY shooting a stronger stream with the Bosch '010' pump installed than last week with the CM30. Car is just an absolute BRUTE. What fun.
PDC...you have the model number on Bosch?
Old Jul 17, 2012 | 12:47 PM
PDC's Avatar
PDC
2006 SL65 ///AMG - GONE BUT NOT FORGOTTEN: 2005 E55; 2002 ML55; 2001 CLK55; 1992 BMW 850i; 1991 M5
MB Part Number - a 000 500 03 86
Bosch Part Number - 0 392-022-010
Old Jul 17, 2012 | 01:07 PM
AMGfan's Avatar
Thank you PDC!
Old Sep 18, 2012 | 10:07 PM
owen powell's Avatar
2003 cl55,04 CL55, 06 SL65
johnson pumps
It sounds like you got a 10-24503-03 johnson pump for your SL65. It is a cm30p7-1, but it has 16mm hose sizes, and pumps 4 gpm. The same thing happened to me. the correct number is 10-24504-03. it has 20mm hose sizes, and is rated at 7gpm. I was unaware there were different "long numbers" that fell under the cm30 heading until I got one shipped to me.
Old Sep 19, 2012 | 11:31 AM
PDC's Avatar
PDC
Owen, as soon as I read your post, I had to run downstairs and check the old Johnson CM30. (I keep all my old parts, God only knows why) Believe it or not, I did have the 10-24504 version with the 20mm inlet and outlet. I will say that the IATs were noticably higher with that pump than after instlling the Bosch 010 pump. Maybe I just got a bunk unit? I know that the CM30 in my old E55 that my neighbor bought is rock solid. That car runs cool and strong.
Old Sep 19, 2012 | 03:14 PM
Wow that scares me! I just removed a 010 bosch pump to install a johnson. The body shop had the bumper cover off for painting rock chips, and I have only had the car for a month, so I took the opportunity to change the pump and add a second H/E with fans. Now I wonder if I should have left the Bosch pump on there. I know people say the 010 Bosch is a new style replacement, but the date code on the one I removed was 10-1-03. That means the 010 has been around for 10 years!
