SL55/63/65/R230 AMG: KLEEMANN SL63 Manifolds
Old Jul 18, 2012 | 03:42 PM
Cory @ Kleemann's Avatar
Former Vendor of MBWorld
I have 2 sets of the KLEEMANN manifolds left on the shelf and will let them go at $995.00 a set. Includes a down pipe with high-flow cat, hardware, gaskets, etc. Shoot me an email if you'd like to pick up a set. cory@kleemannusa.com
Old Jul 18, 2012 | 04:21 PM
COBRA63's Avatar
C63
what are the gains on those? do you have a before and after dyno sheets?
Old Jul 18, 2012 | 04:43 PM
Dyno attached. Tests were done within 2 days of each other, manifolds/down pipe/high flow cat, and the ECU tuned for 91 octane with zero adaptation miles on the car- went from the lift straight on to the dyno. I'd guess the car picked up another 5 maybe 10 wheel HP after it adapted.
Old Jul 18, 2012 | 11:14 PM
COBRA63's Avatar
C63
Thank you Cory.
so the gains are 35 HP with a tune+ Kleeman manifolds and downpipes what type of dyno was this?
Old Jul 19, 2012 | 10:41 AM
Correct, that is what that car did, on that day, on that dyno- your results may vary slightly, but generally, 30-35 WHP can be expected. KLEEMANN uses dynamometers manufactured by a Danish company called DynoMET.
Thank you Cory.
