SL55/63/65/R230 AMG: overZealous1's build thread
#576
Wow holy spacers batman! Car's looking great. What kind of time frame do you think you have before it'll be ready to go on the road again?
#577
thanks. i finally saw the light at the end of the tunnel yesterday. now all the windows are working correctly and top is working too. most all weatherstrip is on also. these were all things that i thought would give me grief knocked out in one day!
the cut and buff will be about 3 days, so it should be good to go by next weekend.
#578
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Hey Oz, quick question, with the harness kit you purchased for the headlights, did it come with a plug for the autoleveling plug too?
#581
it is. had hood in one of the rooms in the house till i put it on and low and behold it had a chip right in the very front of hood. either the gf or the dog has some explaining to do!!
luckily, with this color you can do almost perfect seemless touch ups. main reason i chose it.
#582
i usually do an initial cut and buff, then 5 or so months later do another cutting with just 2000 grit paper. thats when i get all the flaws out.
#584
they do. they air out quite abit and shrink. more coats, more time. i didn't get a chance to bake it too. anything below 70 and it can't fully cure, or takes a huge amount of time longer to fully cure.
We have painted stuff too long (more than 40 ft) for our ovens that air dry. Man is that stuff expensive.
#586
03 RS6
http://www.defelsko.com/applications...-detailing.htm
Got Fiberglass? haha
#591
Multiple Options.... Like detailers use... Example:
#592
#593
i like having that much clear, i can finish doing my body work with it when sanding, hahaa. this color is looking super deep after the cut and buff. it is hard to explain. if you have ever seen paint with zero scratches, it is a beautiful thing!! even a clean finger tip will leave scratches if rubbed on the paint even lightly, really hard to keep it that pristine and drive the car. lots of wax helps protect from that little stuff though.
#594
03 RS6
Just another heads up... you might want to opti-coat it after you have the clear perfect, That won't happen anymore
#598
usually just a couple coats of a good wax is what i need. still huge maintenance to keep the contaminants completely away though. especially if you park under a tree or outside for any length of time. the wax does help them wipe off easier though.
#599
03 RS6
Well it's actually more of a semi permanent protective coating.. there is multiple different types... including this...
http://esotericcarcare.com/22PLE/
Makes it so you don't really have to wipe anything or touch the car for 99% of stuff that touches it... just some good ol' water beading off everything.
