SL55/63/65/R230 AMG: Sl55 172mm? looped fuel system?
My question is if anyone has stacked pulleys such as a 172mm crank and S/C together and what power gains can be expected without a 82mm throttle body or headers and my current set up? I'm going to get the 172mm crank pulley and stage 2 fabtech looped fuel system next unless there is a better modification you guys can recommend. My current budget is $2,500 and my goal is to get the most power for the buck.
Phillip
Why "stage 2" fuel rail I thought that was only if you are going with meth? I would also get headers first
It's almost Black Friday so jump in quick, I would go
Kleemann Headers
Fuel Rail stage 1
Trunk or Engine Bay Tank with split cooling
If you can stretch the budget a little (or get a good discount) then add a 180mm pulley as well
