SL55/63/65/R230 AMG: RAWAMG build is on!
PLATINUM SPONSOR
More pics! Great show and build so far.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#42
looks good! did those rear band clamps clear your hood though? i would check and make sure they don't try to dig into it. might be better to run them so bolt goes flat across the top level with hood.
#44
Fixed... bolts trimmed & then rubber stops added to the ends to be safe
#49
Alright guys I know that it has been a minute since I updated this build & that is partly because Steve & I have had our differences... with that said his work is done at this point.
Now that I have the car back I wanted to let everyone know what I think about what has been done so far.
82mm T/B - I needed a new T/B so I had him install his 82mm & I really do like how he has adapted his version to the inlet without using an adapter plate, it just looks more stock this way IMO
CAI - Everyone has now seen the CAI that he has come up with & I can say for sure that it looks way better in person! I don't know how much better performance it is going to give me but the car looks & sounds a lot more BEASTLY than it did before I went with the polished version & the guy that he uses to do this does a GREAT job!
BWK - Had him install a BWK (I think we all know where this came from) & NO MORE chirp! This is a must for all I don't care who you buy it from... get it if you don't have it.
Surge Tanks & Valve Covers - The guy that he used to do these did a stellar job & I love the pop of the red when you open the hood!
H/E - Time will tell on this guy... it looks solid & every time I have driven the car it has stayed at about 80 & it used to push up much further than that before so it is doing it's job.
I did get his looped fuel rail & a set of Bosch 550cc injectors & I don't really have much to say here... honestly after reading a bunch of post & talking to a couple of different tuners & shops now I may actually put my OEM rail back in the car? I am not saying that there is anything wrong with the one that Steve did up for me (if I do decide to take it out it will be for sale) I am just convinced now after learning better how our fuel system works that it isn't needed. With that said it looks solid enough that I might just leave it as is.
I am glad I have my car back BUT I still have work that needs done so we will call this Phase I... Phase II post coming soon
