SL55/63/65/R230 AMG: +-+-+-Official AEROFORCE TECHNOLOGY GAUGE Release+-+-+
Old 02-06-2013, 03:01 PM
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Let me explain the two versions for the Mercedes:
The first gauge communicates with the ECM (Engine control module), using the ISO protocol used by Mercedes. The second communicates with the TCM (transmission control module) and uses the CAN protocol. This is the first application that we've seen that has two protocols on the same car, thus the need for two gauges unless you don't care to monitor the trans parameters.
There is no wideband specific gauge. Both the ECM and TCM gauges have 2 analog inputs which can be used to connect to our or any other wideband kit. A conversion is entered into the gauge to convert the voltage to A/F ratio. These inputs can be used with temp sensors, pressure sensors, EGT etc. Aeroforce sell wideband kits if you dont already have one.
We have a third gauge called the Analogic, this one does not connect to the OBD2 port. It has four 0-5v inputs and 2 EGT inputs. This is a good choice if you are adding a lot of additional sensors or have a pre-OBD2 car.
Listed Below are some of the PID's available for each gauge:
ECM Gauge Using the ISO protocol
1.Intake Air Temp
2. Coolant Temperature
3. RPM
4. Boost – inHg/PSI. Derived from MAP sensor subtracting barometer.
5. MAP kPa – Manifold Absolute Pressure displayed in kPa
6. MAF lb/min – Mass Air Flow Sensor
7. Throttle Angle
8. Ignition Advance
9. Engine Load
10. MPG – Calculated miles per gallon
11. HP – Calculated HP at crank
12. Battery – battery voltage
13. Inj. PW 1 –Injector Pulse Width for injector #1
14. Inj. PW 2 –Injector Pulse Width for injector #2
15. Oil Temp
16. Oil Level mm
17-24. Knock C1-C8 –knock retard cylinder 1-8
25. O2 B1 mv – O2 sensor output for exhaust bank 1
26. O2 B2 mv – O2 sensor output for exhaust bank 2
27. Analog 1 – analog input 1
28. Analog 2 – analog input 2
TCM and uses the CAN protocol
1. TCC Slip – Torque Converter Slip
2. TCC Slip DSRD –Torque Converter Desired Slip
3. TCC State – Torque Converter status:1=unlocked, 2=partial lock, 3 = lock
4. Gear Actual –Current transmission gear
5. Torque – torque delivered to transmission
6. Output shaft –transmissoin output shaft speed
7. Gear Target –Transmission target gear, will updated just before shift occurs.
8. RPM
9. Turbine in SPD –engine output shaft speed
10. TCC DC- Torque converter clutch duty cycle
11. Analog 1 – analog input #1
12. Analog 2 – analog input #2
We will run a group pricing only for 3 weeks, and is as follows:
Single Gauge-$219.00
Dual Gauge-$379.00
Wideband-$179.00
Partys that want to go ahead and pay, the details are:
sales@buckhead-imports.com
Available Universal Gauge Pods:
Old 02-06-2013, 09:13 PM
overZealous1's Avatar
sl55 amg
dam! good prices on those. would have been all over this 2 months ago.
Old 02-06-2013, 10:00 PM
edin_sl55's Avatar
2003 Mercedes SL55
Do you offer anything that would fit in the ash tray and read afr, oil press,water temp, boost etc?
Old 02-07-2013, 03:40 AM
SL55K's Avatar
AMG
I WANT
Old 02-07-2013, 03:45 AM
0-60Motorsports's Avatar
W124 E280 95
I SENT YOU GUYS EMAILS! Please answer ASAP> Thanks.
Old 02-07-2013, 09:48 AM
pics added up top.
Old 02-12-2013, 10:20 AM
pigskinplayers's Avatar
SL55 AMG
PM Sent
Old 02-22-2013, 08:36 AM
Just wanted to mention some things that you guys may ask about:
1. Both the trans and ecm gauge should be connected to switched 12v power using the included 3 wire harnesses. They will not turn on/off properly using OBD2 power due to the way the ISO protocol works.
2. The gauges may or may not come with the red 2 pin jumper on the back of the gauge. The instructions say to remove it, some may not and the gauge will not turn on properly. Remember to remove the jumper.
3. The user manual for this gauge is V5.2 found on our website here:
http://aeroforcetech.com/files/Interceptor_USER_MANUAL_rev_5_2.pdf [1]
It's pretty simple to install and use.
Old 03-08-2013, 09:12 AM
Up top
Old 03-08-2013, 09:48 AM
RAWAMG's Avatar
SL55 AMG EC Stage 5 Beast / ESS S/C E92 M3
I had Shardul get mine for me since he was making my pod... this combo is great
Old 03-18-2013, 11:57 AM
SL55 AMG
Update...just received my gauges. Now I just need to get them installed in the ride! I like that they come with two bezels and faceplate color options. I decided to go with White/blk to match theme on the car.
Old 03-18-2013, 01:53 PM
Kreuzfeuer's Avatar
SRT-6
These are clean... I'm tempted. I already have a dual-gauge pillar pod for my SRT-6, just need some proper gauges to throw in there. One gauge will be the wideband AFR, but the other one...
Old 03-26-2013, 10:58 AM
Sale is still running
Old 03-26-2013, 11:00 AM
Kreuzfeuer's Avatar
SRT-6
Mind if I share this on the Crossfire forums? The SRT crowd might have some interest in these.
Old 03-26-2013, 11:14 AM
I am not sure if they are compatible with the crossfire protocols. Do you have the ISO and Can protocols to like the C32 AMG?
Old 03-26-2013, 11:33 AM
Kreuzfeuer's Avatar
SRT-6
I'm 95% sure they're the same... I know the drivetrain and engine management in the SRT-6 is virtually identical to the C32 and SLK32.
Old 03-27-2013, 09:46 AM
I am confirming with Aeroforce on capatibility for you homey.
Old 03-27-2013, 11:46 AM
Kreuzfeuer's Avatar
SRT-6
You da man!
Old 04-23-2013, 09:44 AM
We are still running this sale guys.
Old 04-25-2013, 11:20 PM
Stevant's Avatar
2005 SL55 AMG
Ok, I am reading all the info on these gauges and I want to be able to monitor my engine and tranny. I am reading that you get a split cable when you order the dual gauge set-up. I see it uses the OBD2 port. Do both gauges plug into the same port??
Old 04-25-2013, 11:49 PM
SL55 AMG
Yes both are off one master plug that then splits into two leads for the two gauges.
Old 04-26-2013, 12:31 AM
Stevant's Avatar
2005 SL55 AMG
Install
Was it an easy install? The replacing of the pillar and running the wire down to the OBD2 port??
Old 04-26-2013, 12:36 AM
SL55 AMG
Install was a breeze! It took all of about 15-20 mins and that was because I wanted to make sure to not scratch the new pillar. I was extra careful. But it really is a 10 min job and then the time it takes to setup the gauges with the info you want. Very easy install all around!
Old 04-26-2013, 12:32 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Post some pics of the pillar pod installed
Old 09-09-2013, 08:34 AM
Monday morning bump
Quick Reply: SL55/63/65/R230 AMG: +-+-+-Official AEROFORCE TECHNOLOGY GAUGE Release+-+-+
