SL55/63/65/R230 AMG: R231 SL550/SL63 steering wheel conversion?
https://mbworld.org/forums/sl55-amg-...-projects.html
the feature is perfect here with this provider:
https://www.instagram.com/77performance/
www.facebook.com/77performance
look for these airbag part numbers only
A 230 860 xx 02
with "xx" being 09, 10, 15, 16, 17, 18, 20, 21, 23, 28
worth mentioning, if you are doing this on a 2003 through 2006 (sl55 or sl65) you will also have to install the plug and play "paddle converter module" in order for the paddles to work. 2007 and 2008 are already set up for digital paddles (and do not need this digital to analog paddle module) so the paddle will be plug and play.
if you need more info about the paddle converter module, send me a note. It is available from forum sponsors DCT Motorsports and VRP , or directly from me. In Europe, the module is available from comandonlineuk.
Cheers,
Chris
worth pointing out that only 2007 and later R230s (AMGs) support the aluminum paddles ... if you are working with a 2003-2006 R230 (AMG), the paddles need the paddle converter module to be plug n play.
Hope that helps.
Chris
test fitting 2003-2006 sl55/65 button PCBs being re-tasked as the interface (N135) ... CLS N135 module shown in background
2009 SL55 buttons hardwired to new interface
re-assembled and ready to install
Hope that helps.
Chris
