SL55/63/65/R230 AMG: GMP Performance- 55 AMG Carbonio Intake and Engine Cover Special
Former Vendor of MBWorld
W211 E500 Estate
A Carbonio carbon fiber engine cover is a stunning touch to your 55 AMG engine while an intake system is not only stylish but a performance boost as well. Both will wow when you open the hood and both are now 10% off from GMP Performance.
The Engine Cover
An autoclaved carbon fiber engine cover benefits from our industry leading composites manufacturing expertise to give your AMG engine a stunning finishing touch. A direct replacement of the factory part, this is a beautiful accent for Mercedes-Benz’ famous supercharged 5.5L V8.
- Autoclaved pre-preg carbon fiber construction
- Clear coated with automotive urethane and hand polished to a mirror finish
- OEM perfect fit
- Installs in less than 5 minutes
- Unlimited mileage guarantee
The Air Intake
The increased volume and optimized shape of our performance airbox greatly enhances both the horsepower and torque of Mercedes Benz’s legendary AMG 55 Kompressor engine. Autoclave cured carbon fiber keep inlet temperatures cool while an internal airflow regulator ensures smooth power delivery and sharper throttle response.
- Substantial increase in airbox volume compared to factory components
- Autoclaved pre-preg carbon fiber construction, clear coated with automotive urethane and hand polished to a mirror finish
- OEM perfect fit
- Installs in less than 30 minutes
PERFORMANCE:
- Power increase: 16-18 hp
- Torque increase: 17-21 lb/ft
These can either be ordered as only the cover, only the intake, or as a kit with both! Contact us for more information!
The Engine Cover
- OEM perfect fit
The Air Intake
- OEM perfect fit
PERFORMANCE:
