SL55/63/65/R230 AMG: Changer Crank Batterty now battery light is on
2007 SL55 AMG 2016 S550 Coupe
I opted to change my crank battery today instead of letting the dealer charge me about $200 more than what the battery cost at there parts counter. Took maybe 5 minutes, however now I have a red light on the instrument panel that says "Battery". car cranks and drives fine. Everything works, just can't get this light to go off. It's got to be something simple. Anyone know how to get rid of this???
THANKS!
THANKS!
PLATINUM SPONSOR
Did you re-set all your settings yet? Windows, Steering wheel, sun roof? You may try and disconnect the battery again and see if that helps but you will have to re-set all your settings again.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
R230 dual battery system tech training info,
http://www.mercedestechstore.com/pdf...2011-28-02.pdf
Per the guide above, the starter battery fault cannot be cleared at a consumer level - requires star/sds/das
