SL55/63/65/R230 AMG: Wheel seperation
Old Sep 8, 2014 | 10:39 PM
Yachts/amg's Avatar
2003 sl500
Wheel seperation
We have been having a ticking noise coming from the left front for the last 2 weeks the local shop said several of the small bolts that hold the two piece wheel together had come out or backed off. Has anyone else had this problem? If so was it just replacing the bolts?
Old Sep 10, 2014 | 11:14 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check your 2 piece rotors. when the retaining bolts fail they make a ticking noise also
Old Nov 18, 2014 | 11:54 AM
Vetluver's Avatar
SL 65 AMG and E63s AMG
sl65 wheel ticking
mine are doing the same thing. Dealer has taken them apart and found cracked rim. They are under warranty so a new one is on order. Backordered that is until Dec 6. BTW I tightened the screws gently but it made no difference. Please post the answer when you find out.
Old Nov 18, 2014 | 02:25 PM
aeroman's Avatar
1992 911 C4, 2008 P2 E63 AMG (gone but not forgotten), 2007 SL65 Renntech
Great after I just had mine over 180MPH. Now I got to go check each one of those bolts.
Old Nov 19, 2014 | 02:32 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
My left rear on the SL is clicking too. I took it apart and checked the torque on everything, all is good. It's 100% coming from the wheel.
Old Nov 22, 2014 | 12:21 AM
spartan7669's Avatar
sl55 widebody - built viper - ls1 turbo 350z
you sure the lug bolt isnt going into the hub slightly and touching the ebrake springs?
Old Nov 23, 2014 | 06:09 PM
100% sure
