SL55/63/65/R230 AMG: Anyone want to take a stab at diagnosing this?
Old Jan 9, 2015 | 11:32 AM
blknlow's Avatar
2004 sl55 AMG
Just recently bought the car. I knew it needed some TLC. I've read the forums and have heard that the sl55 has its fair share of rattles and clicks. However, I'm slightly concerned with this surging/vibration.
It sounds like it may be the power steering pump, but fluid level is good and viscosity is sound.
I have already purchased a new supercharger clutch bearing and will be installing this weekend, as well as valve cover gaskets.
Thank you in advance for any comments or advice.
https://www.dropbox.com/s/13khsthpzq...84919.mp4?dl=0
Old Jan 9, 2015 | 01:25 PM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
The ticking is pretty normal. It is the valve train and on every MB I have owned you can hear the valves.
I am not sure about the other sound. Towards the end of the clip is seems to be gone but I would get a stethoscope ($5 at Harbor-Freight) and put it on the PS pump. Remember that the PS pump is a dual pump as it also provides pressure for ABC.
Is the oil from the filler neck or is the cover leaking?
Old Jan 9, 2015 | 01:54 PM
blknlow's Avatar
2004 sl55 AMG
Initially, I thought it was the filler neck. However, upon further inspection, it appears that the entire valve cover gasket is leaking.
The vibration is intermittent. It come and goes. Lessens when I put pressure on the oil dip stick.
