After I did conversion, I had a small leak in the black housing part of the radiatior, a lot of labor went into it.
If you can have your shop run a compression test, and if it needs; change the parts needed, would be a great time..
My went bad about a week after conversion, could it have been from the shop themselves or due to age of the car...I don't know. 3k later...it was fixed.
Here's a quick parts list I've compiled. If anyone can chime in to see if there is anything additional I'm missing that'd be great. Looks like you can go used oem with the exception of the hood (couldn't find a used hood), you're looking at around $4,500 which is pretty fair IMO.
sorry for the old thread, but the headlights bracket number have apparently been updated, and cant get the numbers you have listed anymore, did you say the ones thats come on the standard lights are no good? They look the same
thanks
