SL55/63/65/R230 AMG: 50K miles. What would you recommend replacing in ABC system?
Other problems that crop up:
leaking hoses, which are going to be obvious (take to a hydraulic hose shop to have redone, way cheaper)
car either slowly moves upward with one shock when at a stop for a long time period (10 minutes or so) and then comes down rapidly. This is a sign of a leaking oring on a valve block. Have orings replaced (less than $10). This also applies if the car sags overnight. It is a different plunger in the valve block, but still the same problem.
strut fails- get lifetime replacement from arnott
pump fails- this could show up as either a leak or it flat out no longer pumping enough
There's really nothing else. Accumulators and fluid are maintenance, the rest is sort of as needed.
If I replace accumulators and a hose blows later does that ruin the accumulator? I know pump can be fried if you don't stop but I would hate to have a new accumulator wasted.
If engine is stopped quickly, the pump will not be damaged either.
