SL55/63/65/R230 AMG: R230 Adjustable Coilover Kit : It's Finally Happening!
Old Mar 13, 2018 | 11:57 AM
  #351
FxFormat's Avatar
SL 600
Originally Posted by zebra555
Will ask Sean, if he has any. They put all under trays back and the car sits pretty low now. Sean also told me that I don't need any end links if the car will stay lowered like that, only need them if I decide to raise it up.
What is the sway bar connected to if it's not using end links? I'm rather confused, waiting for pics. Traditional macpherson struts setup you have the sway bar attached to the body of the car by 2-3 brackets, then the end of the sway bars are attached to the either the strut or the control arm by way of end links. If he's not using end links then i'm curious as to what the sway bars end up at.
Old Mar 19, 2018 | 08:25 AM
  #352
F1BHP's Avatar
sl600
I have done everything you can as far as weight savings except for the suspension removal so I will let you know when I finish what the lowest weight can be.
i have done brakes, forged wheels, 2 lithium batteries mounted in the boot for better weight distribution, race seats and many more.
i think I am around 4,100lb at the moment so should be able to get sub 4,000lb with the coil overs.
Has anyone actually proved this coil over system on a V12 yet. I really want to get this done to finish the project off.
Old Mar 19, 2018 | 08:51 AM
  #353
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Are you going to get rid of the convertible roof mechanism? That's what it will take along with the removal of ABC and our heavy seats to see a real weight savings.
Old Mar 20, 2018 | 11:37 PM
  #354
Ed954's Avatar
R230
Waiting on the pictures. Will post them here as soon as I get them.
My sl65 was finished with coilover conversion last week, waiting to fix the brakes now, so we can test the new setup.
Old Mar 20, 2018 | 11:44 PM
  #355
FxFormat's Avatar
SL 600
What did they do about the tandem pump? Which pump did they use for the power steering now?
Old Mar 20, 2018 | 11:49 PM
  #356
Ed954's Avatar
R230
I think Sean was working on the adapter. Forgot to ask about it. Will ask him next time when I call.
Old Mar 20, 2018 | 11:54 PM
  #357
FxFormat's Avatar
SL 600
When Tavarish did his conversion, on youtube, he used an ML350's pump, but on the V12 it's different, so was curious on what they used. An adapter would mean we'd have to get a custom length drive belt. Man times like this i wish i had bought a 55.
Old Mar 24, 2018 | 02:19 PM
  #358
Ed954's Avatar
R230
Here are the pictures of coilovers and sway bars that Sean from VVK sent me.
by https://www.flickr.com/photos/99027385@N02/, on Flickr
Old Mar 27, 2018 | 12:40 AM
  #359
gwelliott's Avatar
SL600
Perhaps I'm stating the obvious, and I've looked at the pictures carefully, but what is the front sway bar connecting to? It looks like a piece of steel blunted off on the ends? Am I missing something here? Is this operational? If so, what is the comparison Vs stock?
Old Mar 27, 2018 | 10:19 AM
  #360
FxFormat's Avatar
SL 600
I'm trying to figure that out too, looks like they're welded to part of the knuckle? wouldn't be hard to design loops at the end of it to connect sway bars to LCA.
Old Mar 27, 2018 | 11:06 AM
  #361
57staff's Avatar
2008 CL550
Looks like they haven't attached the end links yet. There appears to be an ear on the trail/control arms to attach the end links.
Old Mar 28, 2018 | 11:30 PM
  #362
Ed954's Avatar
R230
Guys these pictures are made when Sean was test fitting the prototype. Still didn't see the final version yet.
Old Mar 30, 2018 | 04:30 AM
  #363
F1BHP's Avatar
sl600
When is the road test happening? We need a non biased honest review on this as this could literally make or break our V12’s
Old Apr 2, 2018 | 11:21 PM
  #364
Ed954's Avatar
R230
Hopefully next week. Will keep everyone posted.
Old Apr 6, 2018 | 04:59 PM
  #365
Sean@VVK's Avatar
SL55
Car was a delivered to Ed954 yesterdayy��
On the 80 mile trip down interstate 95 the car rode amazing for what I expected from how high we went on spring rates.
No exaggeration, the car rides better than my OEM sport package 3 Series and feels like it Corners better as well. Many of the bridge pavement transitions on I-95 are downright harsh in the 3 Series but the SL never felt too firm or uncomfortable. The body is very well controlled and even large road transitions are attenuated within 1.5 compression/rebound cycles.
Last edited by Sean@VVK; Mar 13, 2019 at 03:16 AM. Reason: referenced member Ed954 change their username
Old Apr 7, 2018 | 11:44 AM
  #366
BlownV8's Avatar
Can't wait to read Zebra's review.
Old Apr 9, 2018 | 08:00 PM
  #367
BlownV8's Avatar
Looks like Zebra555 is now ED954. Strange, why would you change screen names? Either way, any updates?
Old Apr 14, 2018 | 10:03 AM
  #368
BlownV8's Avatar
Update?
Old Apr 21, 2018 | 10:50 AM
  #369
BlownV8's Avatar
Bump for an update.
Old Apr 21, 2018 | 11:42 AM
  #370
Ed954's Avatar
R230
Originally Posted by Sean@VVK
Car was a delivered to Zebra555 yesterdayy��
Thanks Sean for delivering the car straight to my house!
I changed my screen name for a more professional username.
Update?
Bump for an update.
Just changed the rear tires yesterday, they were really worn due to camber from the lowering links. Went to do an alignment after and was told that the shop folks need to drop the exhaust in order to adjust the toe. The toe right now is something like -62. Plus the car won't start sometimes possibly due to faulty battery and rear pads need to be replaced ASAP. As soon as I fix these issues I will post the real review, but so far I can tell that the car rides amazing, way better than ABC with lowering links, can’t say anything about handling right now due to alignment issues. Will keep everyone posted. Thanks!
Old Apr 21, 2018 | 11:53 AM
  #371
BlownV8's Avatar
Never have I been impressed with ABC save for the exception of cornering stability and soaking up minor road imperfections.
Old Apr 21, 2018 | 12:02 PM
  #372
Ed954's Avatar
R230
VVK kit does an extremely well job ​​​​as far as soaking road imperfections, that I can tell for sure.
Old Apr 21, 2018 | 02:06 PM
  #373
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Can I get mine mailed out then considering Ive been waiting almost 2 year for a functional front sway bar for the V12s lol
Old Apr 30, 2018 | 08:24 PM
  #374
FxFormat's Avatar
SL 600
Any updates yet?
Old Apr 30, 2018 | 11:27 PM
  #375
Ed954's Avatar
R230
Any updates yet?
Waiting on the rear break pads to arrive, so I can drop the car off for break and allignment service.
