Just got SL65 V12 tuned ! but splattering :(
Subscribe
Feb 18, 2016 | 10:36 PM
  #101
"in terms of spark asking a plug to jump an extra 0.3mm would not blow a coil or make a car misfire."
WRONG..
bigger gap means coil will need to produce higher kV and coils could be damaged.
A richer mixture ( i.e. tune ) also takes more spark voltage.
a large gap will also make the electricity find the path of least resistance,
this may be the side of the plug porcelain
the insulator of the plug in the combustion chamber
the spark plug boots inside of the cylinder head
the exterior of the coil or internally in the coil and destroy the coil.
don't believe me read on.
WRITTEN BY: Dan VanderLey / Motorsports Engineer, Champion Spark Plug Co.
Mark Twain quotation – “Thunder is impressive and thunder is great but it’s lightning
that does the work.”
Definition – A device which provides a gap in the combustion chamber of an internal combustion engine across which an electrical discharge may occur which initiates the combustion of an air/fuel mixture.The spark plug performs a simple function in a complex environment. CANDLE IN A HIGH WIND just as in the title the candle is affected by the wind’s characteristics, so in our choice of plugs we must consider not only it’s basic function but more importantly the “wind” it operates in.
1. PARTS AND ASSEMBLY
A basic understanding of the parts and assembly will later help in the application and interpretation of the plug. (Cut-away plug below)
PARTS
A. Insulator – Aluminum oxide ceramic, must have good dielectric and mechanical strength, good thermal conductivity and resistive to heat shock
B. Center Wire – Must have good conductivity and be chemically and electrically erosion resistant (Approx. melt temp. of std nickel is 2500 degrees Fahrenheit)
C. Terminal Stud – Either solid post or removable terminal nut made from mild steel
D. Shell – Extruded or bar stock machined mild steel
E. Ground Wire – Typically made of same material as center wire
F. Washers (internal) material – Copper and steel
ASSEMBLY
A. Insulator – Molded dry under high pressure then kiln fired to vitrification at a temp. above the melting point of steel
B. Center Wire – Two pieces welded together, lower std. chrome nickel, upper iron (for strength in sealing process.) Center wire is dropped into the insulator then packed with sillment powder by a tamping process
C. Terminal Stud – The terminal stud has the cement applied then screwed on and tightened to a specific torque then allowed to dry or bake, providing a gas tight seal
D. Shell – After machining or extrusion the threads are rolled, then the ground wire is welded on and the unit is zinc or nickel-plated
F. Washer Material – Racing plugs then get washers and the insulator unit is placed inside the shell, sillment is added with tamping if the shell is cold pressed or if it is to be hot locked no sillment is added (c types are hot locked; s and v types are cold pressed) finally the ground wire is trimmed and the gap is set
***NOTE: While our racing plugs all have a positive contact between the center wire and the terminal stud, (because of a slight indentation in the terminal stud), not all plugs will show continuity when tested with an ohm meter. This is not a problem as the approx. .002″ gap which the low voltage (approx. 1.5V) ohm meter cannot bridge, causes effectively no resistance to the minimum 5000V of an ignition system. Some plugs have actually had a built in gap to combat a weak ignition/fouling problem.
2. Rating and Testing
A. Rating
Rating is referred to as “heat range”
Heat range is the plug’s thermal characteristics or its ability to transfer combustion heat from its firing end to the cylinder head.
Most heat is dissipated through the threaded and seating portion of the shell
Heat is transferred down the insulator nose to the seating or contact point of the insulator and shell, then out of the shell to the cylinder head.
A longer insulator nose = a hotter plug temp.
The insulator tip is the hottest part of the plug and therefore the part that could cause pre-ignition. For a typical 4-cycle engine this takes place at approx. 1750 degrees Fahrenheit
The rating of a plug’s heat range or its pre-ignition rating is done by an IMEP test.
B. Testing
1. IMEP TEST- SAE standard test # J551, single cylinder, constant comp. ratio, constant spark advance, and full throttle
IMEP rating is established by that power setting just below (1″ baro.) the point where the plug reaches pre-ignition as determined by a temp. sensitive indicator. There is a dramatic increase in cylinder temp. within the first few cycles under pre- ignition/detonation conditions. Higher IMEP numbers (psi) = colder plug. IMEP numbers are only good for comparison of the plugs ability to dissipate heat, not good for choosing a plug based on IMEP or BMEP of actual engine. Even though the SAE IMEP test is actually a load test the test engine design is so different and frictional losses are added back into the equation rendering the final figure useless for actual race engine IMEP or BMEP comparisons.
ex. BMEP = 150.8 X Torque/cubic in.
so for a V-8 310 CI engine with 420 ft.lb. of torque
BMEP = 150.8 X 420/310 = 204.3 psi
IMEP rating for a C57C = 450+
C63C = 370
RV15YC = 200
2. THERMOCOUPLE TESTING – used for establishing baseline temp. curve to determine most effective plug .
ex. idle temps – to determine anti-fouling needs
WOT temps – to determine maximum temps
Any change in the engine design i.e., type of cylinder head, cam, cam timing, comp. ratio, will change the temp. of the cylinder and therefore testing could be done.
Thermocouples are made in all common thread sizes and heat ranges
A thermocouple plug has a small temp sensitive element (a fused junction of platinum and platinum/10% rhodium) on the end of the insulator tip, being temp. sensitive the voltage at the junction increases as temp. increases and can be correlated to show exact temp. of plug at T.C. position.
3. FLAME ANALYZER or PRE-IGNITION TEST – basically a power source supplying a constant 10V to the spark plug with an oscilloscope showing the voltage curve indicated by the current flowing through the ionization of the plug gap.
From this curve we can determine:
1.burn rate of fuel mixture
2. auto-ignition – this is determined by intermittently removing the electrical charge from the ignition system to the spark plug and observing an ignition of the fuel at some point after the preset ignition time.
3. pre-ignition – when auto-ignition crosses to before set ignition timing. This test indicates how close to pre-ignition a plug is, allowing as hot a plug as possible to be chosen.
4. plug fouling – the baseline current flow increases as the plug becomes more fouled
4.ELECTRODE EROSION TEST or ENDURANCE TEST – subjecting the electrodes to a highly corrosive environment within the combustion chamber i.e., different fuels, lubricants, cylinder temps., ignition current, etc., to develop a product that will last
3. FACTORS AFFECTING PLUG PERFORMANCE
1. FACTORS AFFECTING THE TEMP. OF THE PLUG
Engine speed and load – as you increase RPM and load on an engine the temp. of the plug increases
Ignition Timing – great effect on plug temp., even after power curve has dropped off, increasing the timing with the engine under a load will result in a hotter plug temp.
Horsepower/Torque Increase – most changes that increases the power will result in an increase in plug temp. (ex. increasing comp.)
Cylinder Head Temp. – insulator tip temps. vary almost directly with cylinder head temp. When changing cylinder heads the cooling capability around the spark plug should be considered. Some later design heads have no water jacket around the plug hole.
Denotation – causes extreme and rapid rise in plug temp. which can then lead to pre-ignition and plug damage.
2. FACTORS AFFECTING THE VOLTAGE REQUIREMENT OF THE PLUG
Gap Spacing – With increases in gap comes an increase in “start up” voltage, but the “lock in” voltage remains relatively the same regardless of gap. Ex. fluorescent light – a 1′ long bulb or a 6′ long bulb use a very similar amount of voltage to keep the gases ionized but the larger bulb requires a substantially larger voltage (ballast/transfmr) to initiate the ionization.
Electrode Temp. – as the insulator temp. and electrode decreases the voltage required to create a spark increases. This is not so critical at higher RPM where the plug temp. is relatively high regardless of the plugs heat range, but it could be critical on a cold plug/low RPM situation where a weak spark could promote fouling. Note * lower power race engines require as much ignition as their higher power cousins because though igniting the mixture may be easier due to lower compression it’s made more difficult because of the lower cylinder temp. and too good a fuel quality.
Fuels – fuel conductivity will affect the voltage requirement in that a very conductive fuel can, when it wets the spark plug, bleed off a portion of the electrical charge. A good example is methanol which is a very conductive and requires and very strong ignition system.
3. FACTORS AFFECTING THE EFFICIENCY OF THE PLUG
Plug Location – most important factor concerning the plug next to the heat range. The first 10% of flame burn greatly affects the remaining 90%, i.e. if the flame burn begins very slowly the remaining comb. process will take place at a slow rate, therefore the manner in which the flame front is initiated is very critical to the engine’s performance. With that said it is obvious that the plug should be unshrouded to promote a larger initial flame kernel.
Some theories on plug location:
1. Plug should be centrally located in the combustion chamber so the flame can spread omni-directionally resulting in a faster burn rate. Minimal length of flame travel = faster burn rate = quicker pres. rise = less denotation tendencies
2. Plug should be located near the exhaust valve – having a hot exhaust valve located near the end gases promotes denotation, therefore locating the plug near the exhaust valve places the end gases in a cooler environment resulting in a decrease in denotation, this plug location also promotes rapid combustion because the heat from the exhaust valve promotes the 10% burn rate resulting in less ignition timing needed with a more rapid pressure rise.
3. Plug location relative to the swirl within the combustion chamber – there are two schools of thoughts on this:
A) Consider a turbulent mixture of vortices, if the spark occurs at the center of a vortex (a), the flame must spread without the aid of turbulence until it reaches the vortex boundary, on the other hand, ignition at the vortex boundary (b), will immediately aid the spread of flame because of the shearing action encountered.
B) A plug located on the vortex boundary can become so beaded with fuel wet fouling can occur (most common at lower RPM) ex. restart hesitations experienced by methanol fueled sprint cars
Multiple spark plugs – can reduce cyclic variation in the 10% fuel burn at lower RPM because there is a better opportunity for the ignition point to be in a proper air/fuel mixture and be near a vortex edge to propagate the flame. Also used in applications where large amounts of fuel are making it difficult to ignite the mixture, in this case 2 plugs are used with 2 separate ignition systems to create enough heat (current density) to reduce misfires. Can also reduce denotation because of reduced combustion time, provided the spark is retarded enough to hold peak pressure at optimum value. The negative side to this arrangement is that the multiple flame fronts create a lean spot where they meet thus creating less power and potentially harming the engine. In an ideal engine a multiple plug arrangement would show no benefit over a centrally located single plug but there is no ideal engine.
4. PLUG TYPES – FACTS AND FICTION
Resistor/ Suppressor – its function is to control electromagnetic interference. In a racing engine with a capacitive discharge ignition it will slightly lower the energy delivered at the plug gap. A possible benefit may be that with so much electronics being used in today’s racing, (engine management systems, date acquisition systems, etc.), the reduction of the electromagnetic interference may be very important. However with high output ignitions the resistor may burn out.
Gap Styles:
1. Standard Gap or J-gap – places spark plug approx. 1/16″ in the combustion chamber. Can be used with the ground wire in the Full coverage, Half coverage, or Corner gap configuration. Less gap wire coverage tends to give better spark exposure, because the arc is not behind so much of the ground wire. The arc tends to take place at the point of least resistance which typically is the shortest distance between to points. That is normally on the back side of the center wire because of the turn down of the ground wire going towards the shell. Also in the cold heat range plugs the ground wire becomes the hottest point in the combustion chamber and thereby the limiting heat range factor so shortening the ground wire may add a bit of insurance by reducing this hot spot.
2. Projected Core Nose - places the spark an additional 1/8″ into the combustion chamber. Originally designed to prevent fouling by exposing the insulator/ center wire to the air fuel path and heat of the cylinder. In street applications it performs as a hotter plug at lower RPM while running cooler at higher RPM. This is due to the cooling effect of the fuel charge on the projected tip. In racing it does the same thing, however it has limitations because the core nose length and the long ground wire limit the ability to build the colder heat ranges in this configuration. If this plug could be built in a colder heat range it would be ideal for super-speedway use, but as it is its use is normally limited to short tracks, some road courses, and sometimes qualifying on the big tracks. Because it physically moves the ignition point it can more centrally locate the ignition which reduces combustion time. It can also place the ignition point in a more efficient location based on swirl. In some cases this plug has the same effect as increasing ignition timing.
3. Retracted Gap - designed for high out-put engines where plugs could not be built cold enough with regular style ground wires. For use in F-1 and Indy style engines with very high cylinder pressures and temps. and ground wire clearance problems. Some of these plugs have silver center wires to further help dissipate the heat. This type of plug should only be used when absolutely necessary as it provides the least amount of combustion incentive of all the plugs.
4. Surface Gap – originally designed for outboard 2-stroke engines which had a bad fouling problem from dirty fuel causing major deposits on the insulator which in turn caused pre-ignition/denotation. These plugs are so cold they have no measurable heat range, they also require a very high energy CD ignition system. We have recently added a “surface air gap” plug which does have some insulator nose length giving it a measurable heat range. These plugs are very popular in the current F-1 engines. With the fine center wire. (.052″), and somewhat exposed core nose this plug works very well with high energy ignitions.
5. U-Groove Ground wire – the only possible advantage to this plug would be a more exposed spark due to the fact that there is no center of ground wire to fire to. The same thing can be accomplished with a fine ground wire/corner gap design. Nelson Crozier had a conversation with one of the engineers from Nippendenzo who was involved with the development of this plug and he relayed that the reason for the U-shaped ground wire was to eliminate a shell distortion problem they were experiencing when welding the full size ground wires on the shells. (the larger wire takes more heat in welding)
6. Split-fire/Ring-of-fire – again the only possible advantages would be (1) better spark exposure by splitting the ground wire around the center wire, however in this case the ground wire actually has more mass so it’s arguable that the center wire is actually more shrouded and (2) it has more sharp edges for a longer wear life, but this additional area can also be more hot spots in a racing application resulting in pre-ignition. As for the more spark energy claim, as long as you compare “apples to apples” there is no difference in these plugs compared to any other standard gap plug. Where there could be a difference is if we were to compare say, resistor to non-resistor or an auxiliary gap plug to a standard plug. Concerning the claim of multiple sparks, the natural act of lightning is the best example of “one charge/one arc” simply put if the plug receives one charge it will deliver one arc. There are some small re-fires, due to a small amount of energy left in the coil, but they are not significant to the plugs performance.
7. Fine Center Wire/Ground Wire – originally designed to improve starting and anti-fouling characteristics in small 2-stroke engines. The small center electrode reduces the voltage required to fire the gap. A smaller cross sectional area ground and center wire can also give a more stable ignition resulting in less cycle variations. Another advantage is that the smaller (.052″ vs. .100″) center wire allows the insulator to be smaller in diameter which increases the bore clearance volume, this results in allowing more fuel charge in and out of the plug which helps to keep it clean, resisting fouling, and gives it better exposure to the fuel for improved ignitability. These plugs have been tested and proven to be able to fire under greater pressures than the std. dia. center wire plugs with similar ignition systems.
8. Bullet Nose or Extended Surface-air Gap – with the recent problem of ground wire failure this could be a solution in the cases where no type of normal ground wire will work.
Special center wire/ground wire materials - the copper cored and silver center wires are primarily designed to pull the heat out of the firing end of the plug, all the other precious metal designs however are primarily used for their durability factor. It should be also noted that the precious metal center wires encourage the spark to leave because of the free electron they possess. In the street application these plugs are great as they sometimes won’t need to be changed for the life of your car, but for racing they have little application unless someone comes up with an ignition or fuel that is particularly erosive/corrosive. There is one thing that is of some interest and that is that platinum is a catalyst for alcohol, (specifically methanol and ethanol), and with the search for alternative fuels and octane boosters, with alcohol being one of the leading candidates, and the strong push for long durability plugs, and platinum being one of the popular choices there is a real potential problem. With all this said you definitely should never run a platinum plug in your your alcohol fueled race car.
Different size plugs (10mm, 12mm, 14mm) - as plugs get moved around more there is increase in the usage of smaller diameter plugs because of the physical limitations of the cylinder head, with the increase in usage has come an increase in the number of complaints of shell failures, i.e., breakage of the shell at the base of the threads. These failures do not occur because of poor manufacturing but because of a lack of knowledge concerning their torque specs.
Average torque rating: 14mm – 28 lb.ft. — 12mm – 15 lb. ft — 10mm – 10- lb.ft.
The cross sectional area of a 10mm shell is almost 50% less than that of a 14mm shell. Plug manufacturers have preached to the F-1 guys for years about using a torque wrench when installing these 10mm plugs, you just cannot rely on “feel”. A 10 mm plug shell has comparable cross sectional area to a 1/4″ bolt. So the next time you install a 10mm plug think of it as a mild steel 1/4″ bolt. The reason the shells cannot be made thicker is because to do so would decrease the insulator size and the dielectric strength would not be sufficient to prevent holes from occurring in the insulator. So it’s a trade off between shell strength and insulator dielectric strength.
Tapered Seat vs. Gasketed Seat - with some of the new cylinder heads both the tapered seat and the gasketed seat are machined allowing the user to make the choice. Originally the tapered seat design was made only because in certain applications the physical dimensions of the gasket and the 13/16″ hex were not acceptable, however now with the new design 5/8″ hex gasketed plug the problem is not nearly so bad and the gasketed seat plug is regaining its popularity. Concerning seating there should be no difference. The typical arguments for these plugs are – with aluminum heads moving around like they do, due to thermal expansion and contraction, there could be a leakage problem with the tapered seat – with the gasketed plug the gaskets could have a problem with proper crush. Neither of these arguments hold much water as there have been virtually no problems with seating each plug. The only possible advantage of one over the other could be that the tapered seat plug distributes its load in both the X and Y axis whereas the gasketed seat only stressed in one direction thereby exerting more of the force directly to the threads of the plugs and cylinder head.
5. INTERPRETING THE PLUG
Why - because the plug is the nearest thing we have to looking in the cylinder and outside of very expensive data acquisition equipment, (which isn’t always practical, legal, or even available), it is the best indicator of what is happening during the combustion process.
How - very important - with a light of proper magnification and brightness. This seems so simple but many people misread a plug because the light is too dark, keeping them from seeing the plug as it really is and causing them to “read” shadows. Also it is important to find a good magnification and stay with it. (I prefer a magnification that allows me to see details, such as denotation and oil spots and still lets me see the whole firing end.) Changes in magnification greatly change the “look” of a plug and if you are not familiar with it, it will only cause to confuse you.
Test Conditions:
1. Should be a new plug – some markings such as denotation and oiling will not burn off so it becomes difficult to see changes when the plug is cluttered with old information.
2. Need a good, clean power shut off – this does not mean at wide open throttle and 300 MPH flipping the ignition switch! It doesn’t hurt the plug reading at all to push the clutch in while backing off the throttle, let the engine stabilize for a moment, and then turn the ignition off. The important thing is to do this check at the highest temp., i.e., the end of the longest run, and not let it idle all the way back to the pits.
3. Be consistent – the engine should be up to operating temp., (water and oil), and be the same from test to test. The duration of the test should be the same each time as well. Anything that affects the engine will affect the reading on the plug, (RPM, air inlet temp. and press., coolant temp., etc.) so keep all the changes in mind while reading the plug.
Things to Look for in the Plug:
1. Air/fuel mixture or fuel ring – look for the color of the ring on the insulator. As the engine gets richer the color ring will get darker and farther up in the insulator nose, (towards the ground wire), as the mixture becomes leaner the fuel ring will become more light brown in color and closer to the bottom of the insulator , sometimes disappearing completely. In the Champion racing plugs a ceramic coating is added to the insulator where it seats into the shell. As we already stated as you tune the engine leaner and the fuel ring goes deeper down the insulator, finally disappearing altogether the next step is going to be the ceramic coating just mentioned, blistering and pulling in on the insulator so that you will see a thin, black, jagged ring just at the bottom of the insulator before it goes out into the shell.
2. Ignition timing – generally denotation is evidenced by the appearance of tiny, metallic looking ***** on the insulator. These specks can be either dark or silver, (indicating aluminum), but are always spherical in their shape.
3. Heat – this is a very critical reading because it it the result of three factors. 1-fuel 2-timing 3-heat range of the plug. Excessive heat is recognizable by a glazing of the insulator and/or a discoloration of the ground wire and center wire. Other indicators of the amount of heat in the plug are the location of the heat color line on the shell threads and the ground wire. At the heat goes up. the color line will extend to more threads on the shell and move farther on the ground wire towards the shell. For me personally the threads are a little difficult to read however the ground wire heat line is fairly visible and therefore easy to see changes in. Once you see the heat in the plug, deciphering which of the three factors are causing it requires a knowledge of the engines performance characteristics and where reading the plugs while the engine is on the dyno (where you have the benefit of power readings) becomes so important. For example, if there is a lot of heat in the plug at the point of best power for timing and fuel mixture, then you should try a cooler heat range plug. If you feel confident about the plug heat range and at the track the plug shows heat then consider fuel and timing. It all requires a great amount of base knowledge concerning your particular engine, and it’s very difficult to look at a set of plugs for the first time and give the “best power” advice. Another issue to consider is that different plugs show heat differently and you should be aware of these manufacturing differences while trying to read them. A good example is the older Champion plugs had cement inbetween the center wire and the insulator, a lot of people looked for this cement to boil out the top as an indicator of heat. This worked just fine but now we have removed the cement, which is going to pose a big problem if you keep leaning down waiting for the cement to boil out. This change also causes the plug to run a little warmer, which causes the insulator color line to appear leaner. Another difference could be the plating of the shell and ground wire. Zinc chromates tend to discolor quicker then nickel coatings, which again would change your impression. The best advice is to remain consistent or understand the changes so they don’t fool you.
4. Similar conditions on all plugs – for optimum performance all of the plugs should look the same, meaning that all cylinders are operating equally and at top efficiency. You must look at all of the plugs when tuning the engine to insure the fact you are seeing the worst case, but at the same time each plug should be treated as if it came from a one cylinder engine. If the plugs vary in their reading it could be either from inconsistent cooling or inconsistent fuel distribution. Fuel distribution problems can sometimes be solved by staggering jetting, (in carbureted engines this generally affects two cylinders per jet), or by manifold porting. Varying plug conditions should not be ignored as they may be the first indicator of a problem which when ignored could develop into a more serious condition. Some people in an effort to make all the plugs look alike have staggered the heat range of the plugs in the engine. While this may be appropriate to say, prevent denotation in a hot cylinder by installing a colder plug while leaving the other cooler cylinders with the warmer plugs, it should be used only as a preventative measure and not be confused with actually solving the causing condition or improving the performance of that cylinder.
5. Strength of ignition – an indicator of the ignition strength is a “spark mark” on the center wire. When a strong ignition is being used there will be a crescent mark on the center wire from the strength of the arc. Sometimes the plugs will, in addition to losing this mark, take on a very cold, rich look when you feel the jetting and timing is appropriate, and the cylinder leakage check proves OK. This can be from a weak ignition and solved simply by changing ignition parts. Many times though this “weak” look comes from a poor electrical ground system. Do not rely on your metal motor mounts to ground the engine, a good strap from the engine to the frame has solved many a weak ignition. The ideal ground system would be to run an 0 or -1 size copper cable from the negative side of the battery, up to a post welded to the frame and then run all your ground wires including the ground strap from the engine to this common post.
Other Problem Indicators:
Oiling – typically a dark shiny look that will not rub off in your palm. Sometimes when the rings haven’t seated completely you will see small, flat, dark spots. These spots can be distinguished from denotation by their difference in shape. Sometimes a large single blotch will appear, this is usually from oil coming down a guide when the engine was off and landing on the plug.
Water in the cylinder – the early indications of a water leak into the cylinder is a lack of any fuel ring combined with a light gray look on the entire firing end.
Additives in the fuel – sometimes when you change fuel brands you will see a change in the look of the insulator. Usually it is a color change indicating a different dye or additive used in the fuel. It may have a yellow color tint or it may have a crystallized appearance. The yellow color typically is a sour crude having a high sulphur content, (western crude oil is a sour crude having a high sulphur content), or it can be from a high amount of lead additive. As for the crystallized appearance some tracks add a small percentage of alcohol to their fuel to absorb the water/condensation that gathers in their large, very seldom full, storage tanks. This alcohol with it’s water can give the insulator a crystallized appearance.
Thread inserts in aluminum heads – this past year we ran across an interesting situation. A racer had stripped out the threads in one of the plug holes of his aluminum heads, so he fixed his problem with a steel thread insert. The next time he ran the car the plug in this hole melted the tip off. What happened is the heat dissipating ability of the head, and thus the plug, had been changed rendering that heat range much too hot. In this case the steel insert certainly had an effect but just as importantly was the Loctite used to hold it in places as the bonding agent created a great thermal barrier.
Heat Range Selection – there are basically two theories on choosing a plug’s heat range for an engine and the tuning that goes with it.
1. Choose as hot a plug as possible – this choice has been the approach for many years and is justified by the thought that you eliminate any low RPM fouling and stumble, and that the hotter plug will light the flame faster at all RPM resulting in a increased burn rate. Advocates of this idea don’t mind cooling the plug by adding more fuel, (richening the engine), and decreasing timing for the race. Most of the supporters of this theory are drag racers, where fuel economy isn’t so important and a slight denotation can be caught before any damage is done.
2. Choose as cold a plug as possible – this is a fairly new idea but is gaining a lot of popularity among the oval track and road racers. The approach here is to run a cold plug coupled with a lean mixture and sometimes an increase in timing. This choice eliminates the possibility of the plug limiting the air/fuel ratio and ignition timing by becoming a pre-ignition point thereby allowing the tuner the ability to find “best power” in both of these cases. Some reports are that fuel mixtures much leaner, and timing higher than previously thought possible have been run with success. This can be a benefit where fuel economy is an issue. Other benefits to the colder plug are that it is more sensitive to tuning changes as not so much of the fuel is burnt off by the insulator heat, also with the increase in compression ratios and subsequently cylinder pressures the colder plugs have provided some insurance against pre-ignition/denotation and are probably much more in-line with the proper heat range for the cylinder temps. In my opinion the only concern with this approach would be in the low RPM situation where there could be the possibility of misfires. However most of the racing done today is at a relatively high RPM and most racers could probably use a cooler plug with no ill effects and the possibility of some benefits, just be sure you have enough ignition.
Thoughts on Special Applications – most of our talk has centered around the normally aspirated, gasoline fueled engines. The following are some thoughts concerning other racing applications.
1. Alcohol Fuel Engines – alcohol is difficult to read on the plug insulator as it burns so clean. Basically you have to look for heat to indicate your rich/lean condition. If the plug looks brand new and the ignition is working OK then you are too rich. Some engine builders look at the top of the exhaust ports to check their fuel setting, with a light brown indicating a good air/fuel mixture. Also keep in mind that alcohol fueled engines are not nearly as sensitive to being rich as gasoline engines are, (a 10% rich condition will show no power loss), so don’t be concerned with the fuel mixture like you would be with gas. If it shows a fair amount of heat and the engine is crisp its probably OK.
2. Nitro methane Fueled, Supercharged Engines – looking at these plugs is like looking down a gun barrel to see the bullet coming – if you see it it’s too late! You should look for heat in the center wire with a light blue being normal and the next step hotter being burnt and gone. Concerning denotation, if you see it in the plug its too late. You’d better start pulling it apart as the piston, rings and/or cylinder will surely be damaged. In choosing a plug for these engines you must consider the tremendous rate at which the heat builds up in these cylinders. It can build up so fast it will cause the center wire to expand too quickly, cracking the insulator radially as well as vertically. Because of this if the plugs are to be used again after one run they should be inspected under an inspection light. Some engine tuners like to run an extended tip plug in order to help keep the fuel mixture from fouling the plug and then they read the percent of ground wire burned off as an indication of the rich/lean condition.
3. 2-Stroke Engines – basically these engines’ plugs read very similarly to the 4-stroke engine as far as the insulator and electrodes are concerned. The shell will always appear a but more shiny, as an indication of the higher cylinder temps. associated with 2-cycle engines. As with the 4-cycle , rich conditions will darken colors where lean will be very reflective and have a glazed appearance. Timing also is similar in its appearance but, even the slightest sign of denotation will destroy the piston and cylinder. Choosing the heat range of the plug is a very critical factor in the 2-cycle engine. You certainly need a plug hot enough to prevent low RPM fouling but if it is too warm the oil in the fuel mixture can become burned onto the insulator, which becomes hot spots when enough has accumulated, creating a pre-ignition situation. The colder fine wire plugs work very well in these engines because of the low RPM anti-fouling characteristics of the fine wire design. The thing to remember is that all of the conditions are more critical since the 2-cycle fires on every stroke, causing less time for cylinder and piston cooling.
CONCLUSION
As we said in the beginning, the spark plug performs a very basic function, it ignites the fuel mixture, nothing more nothing less. This means that if the conditions are correct all the plug “tricks” are meaningless and account for all of the reports that say, “I tried that and it didn’t do a thing.” However nothing is probably less understood, less documented, and certainly less repeatable than the combustion process and all the things that affect it. Therefore, since the spark plug is the initiating factor in this mysterious combustion process it is imperative that we understand, 1. the basic design and materials so that we can make a proper selection 2. the factors affecting the plugs performance so we can most effectively use this plug 3. the plugs abilities so we don’t expect it to do things it’s not capable of and 4. we must understand and be able to interpret what this gauge, the window to the combustion process, is telling us. because there are literally no two identical engines concerning combustion, there are very few hard and fast rules as to application or interpretation and so experience is your greatest asset. The more you look the more you will understand and be able to more effectively tune your engine.
Reply 0
Feb 18, 2016 | 10:48 PM
  #102
What should I gap my spark plugs at?
What dictates the width of a spark plug gap is both the amount of voltage and amperage of your ignition system as well as cylinder pressure and air / fuel mixture density. The rule of thumb is that the more power an engine makes, the smaller the gap needs to be. Race engines (contrary to popular belief) use smaller gaps than most "stock" engines due because of higher cylinder pressures and denser air/fuel mixtures. This is because a small, intense spark is better for lighting a highly dense, very wet fuel mixture like you'll find in high powered race or performance engines, kind of like these new lighters you see these days with a small, intense blue flame. They light cigars, fires, etc better in the rain, wind, etc where a weak yellow flame that you get from a match or a typical Bic type lighter isn't as hot, and easily blows out.
A smaller gap will yield a short, intense spark and will usually make the engine real responsive. A wide gap creates a longer spark arc but without sufficient "juice" from your ignition system, (including amps), can be weak. A small intense spark is MUCH better than a big, weak spark, especially when dealing with richer fuel mixtures and more volumes of fuel being burned.
A good starting point and pretty much all around best gap is .035". If you want to experiment to see what works best for your particular engine, ignition, etc, then try going up to .040" and then .045, noting each time how the engine idles, responds, and pulls. Once you've gone bigger on the gaps, now try going smaller to .032", .030" and .025" and again, note how the engine runs. Whatever the gap was when the engine ran it's best overall, is where you should gap your plugs at.
Just an FYI; most very high powered blown gas, blown alcohol, and even blown fuelers run gaps as small as .026" (give or take) and use ignition systems that use 50,000 - 80,000 volts, but more importantly, up to 40+ Amps! Amps are what kill you. Stun guns have up to 1 million volts, but no amps, so they aren't lethal. Hell, static electricity you get when you shock yourself against a door knob or your car door can be upwards of over 100,000 Volts, but does it kill you? Nope. Your house electrical current can kill you too, but it's only 110 Volts, BUT it has 15 - 20 Amps pushing that Voltage behind it. Get hit by your house's 220 Volt system are you will most likely die. Not because of the 220 Volts. Again, it isn't Volts that kill you (again, think of a stun gun), it's Amps. Most 220 Volt outlets are for running heavier equipment such as your dryer, a welder, etc and have between 20 - 50 Amps behind them. That kind of current will light your *** up and fry you, but a 50,000 Volt jolt from a spark plug won't, unless you are screwing around with a serious ignition system like what a Top Alcohol or Fueler engine runs with 40+ Amps behind them. They even have decals on the tops of the dual magnetos saying "Caution! Lethal Current".
Your ignition system may have lots of Voltage, but no Amperage. This is why even on high energy ignition systems, (CONTRARY to what their lame instructions say to gap your plugs at), you CLOSE the gap on engines making more power. Usually .035" is around the best gap, even though many instruction manuals say to open your gap to .045". Go ahead and try that, but when it doesn't run as good, or it drops cylinders because that wider / weaker spark can't light the cylinders consistently, you'll know why. This gets even more true when you are running too rich and have too wet of a mixture. It's harder to light a fire in the rain than it is on a dry summer day. Inside your cylinder isn't much different.
On mild engines, (even you guys who have 400 - 550 HP), that isn't enough power to be concerned with on the gaps, and a gap of .045" will "probably" run just fine because you aren't burning enough fuel (a wet enough mixture) to cause cylinders to drop with a decent ignition system, but start getting over 600, 800, 1,000 horsepower and that .045" or so gap isn't going to work out too well any longer. Either way, your milder engine WILL run better with .035" gaps instead of the .045" gaps that they tell you to run.
Now, while we're on the subject of gaps, a little extra trick you can do to your plugs is to do what's commonly called "side gapping" them. This is when you take a small file or a fine grinder to the ground strap and cut it back so it only covers about half of the center electrode. This exposes the spark to the open cylinder and combustion area and prevents the shrouding the full length ground strap tends to do on regular plugs. This can be worth a few extra horsepower, just as indexing a set of plugs is worth a few extra ponies.
As you can see in the image, the plug on the left is a typical plug with a full length ground strap, where the plug on the right is side gapped. You can clearly see how doing this exposes the spark to the open cylinder more and will promote better flame travel and combustion. It's free horsepower for only a few minutes worth of effort.
Reply 0
Feb 18, 2016 | 11:05 PM
  #103
do not side gap any coated spark plugs (platinum or iridium spark plugs)
indexing is good only if the correct torque is applied when the plug is indexed.
you did correctly torqued the plugs .. no guess no one asked that question yet.
loose plugs affect heat transfer and will affect performance.
Reply 0
Feb 19, 2016 | 12:01 AM
  #104
M275 = 23 Nm/17 ft.-lbs. on the plugs. 9 Nm for the coil pack bolts.
Spark Plug Installation:
Torque is one of the most critical aspects of spark plug installation. Torque directly affects the spark plug’s ability to transfer heat out of the combustion chamber. A spark plug that is under-torqued will not be fully seated on the cylinder head; hence, heat transfer will be slowed. This will tend to elevate combustion chamber temperatures to unsafe levels, and pre-ignition and detonation will usually follow. Serious engine damage is not far behind.
An over-torqued spark plug can suffer from severe stress to the metal shell which in turn can distort the spark plug's inner gas seals or even cause a hairline fracture to the spark plug's insulator...in either case, heat transfer can again be slowed and the above-mentioned conditions can occur.
The spark plug holes must always be cleaned prior to installation; otherwise, you may be torquing against dirt or debris and the spark plug may actually end up under-torqued, even though your torque wrench says otherwise. Of course, you should only install spark plugs in a cool engine, because metal expands when it's hot and installation may prove difficult.
also lawn mower plugs installation in case you want to blame EUROCHARGED for damaging you lawn mower.
Installing Spark Plugs – Lawn & Garden Equipment
1. Confirm that the thread reach of the spark plug is the right one for your engine.
2. Remove the dirt at the gasket seal of the cylinder head.
3. Tighten the spark plug finger-tight until the gasket reaches the cylinder head, then tighten about ½ - ⅔ turn more with a spark plug wrench.
Reply 0
Feb 19, 2016 | 02:00 AM
  #105
now ill say I bought them from the US and youll say NGK is made in Japan you should of went there picked them up yourself, you guys are never going to see it for what it is and will always see it how youll want to!
Reply 0
Feb 19, 2016 | 12:33 PM
  #106
Quote: actually quiet wrong, I dont skimp (go cheap) on parts all fluids , oils, parts are of the best quality. NGK is not a cheap quality part, the difference is actually in longevity, do I intend to keep this car for another 100,000kms like the plugs suggest I dont really think so. Why would you pay triple the price for plugs if your going to be getting a SLS in a year ?
They dont sell plugs and write on there site they are suitable for Maybachs and Mercedes v12 engines if there not suited to them, this in itself is a lawsuit ! I could potentially sue NGK and get compensation on the damage the plugs created, but it isn't the dam plugs ! I am the one who put the plugs in , I am the one who drove the car with the new plugs in, and I am the one who saw how the new plugs performed! So quit trying to blame plugs that are perfectly fine and made for v12 M275 ! Really you people do not read previous posts, IT IS NOT THE PLUGS! THIS HAPPENED AFTER INSTALLING TUNE!!!!!!!!!!!!!!!
You don't read very well do you? I wasn't saying its the plugs. I was laughing that you would go cheap instead of putting the best in regardless of how long you will have the car.
Reply 0
Feb 19, 2016 | 06:11 PM
  #107
No matter what you'll need to replace both the plugs and coil packs now. The end!! If you choose not to be safe and do it right this time, unlike your first time cutting corners, then you'll have another thread bashing ngk or someone else. Honestly if you needed to buy used coil packs then you should really rethink owing and especially modding this car.
Reply 0
Feb 20, 2016 | 07:04 PM
  #108
Quote: now ill say I bought them from the US and youll say NGK is made in Japan you should of went there picked them up yourself, you guys are never going to see it for what it is and will always see it how youll want to!
So, here I am having recently retired, trying to think of the best use of my time. Currently I am catching up with Oprah shows I did not have time to watch in the past. OMG! An epiphany! This is not "Monsta's" fault. We are all victims and none of us are ever to accept responsibility for our own actions. Seriously, what really offends me about the op is the way he began this thread with an implicit threat. I have a problem, and either you resolve it to my satisfaction, or I will reveal your identity to the forum and try to damage your business. I have been impressed with the patience and attempt to help this individual. Clearly no amount of reasoning with this person will help to alleviate what is becoming clear is a psychological problem. This person does not need help with his car as much as he needs help with his head. To the person in Germany that tried to direct him to professional help with his car. Do you know of anybody in the vicinity that can help him with his particular neurosis?
Reply 0
Explore
Feb 20, 2016 | 07:34 PM
  #109
Reply 0
Feb 21, 2016 | 03:31 AM
  #110
Quote: You don't read very well do you? I wasn't saying its the plugs. I was laughing that you would go cheap instead of putting the best in regardless of how long you will have the car.
Well if the company makes them and recommends them for the car, where exactly is the problem there ? Do you plan to keep your car more then 80,000kms from its reading today? I think my logic is actually right then
Quote: No matter what you'll need to replace both the plugs and coil packs now. The end!! If you choose not to be safe and do it right this time, unlike your first time cutting corners, then you'll have another thread bashing ngk or someone else. Honestly if you needed to buy used coil packs then you should really rethink owing and especially modding this car.
HAHAH im in tears! this whole site is full of improvising our cars and people parting out cars, and using parts that are otherwise re-usable. People open there coils and recondition them, they are good as new , if you are just not capable of carrying out the know how, plus the mods your better of buying "new"
Quote: So, here I am having recently retired, trying to think of the best use of my time. Currently I am catching up with Oprah shows I did not have time to watch in the past. OMG! An epiphany! This is not "Monsta's" fault. We are all victims and none of us are ever to accept responsibility for our own actions. Seriously, what really offends me about the op is the way he began this thread with an implicit threat. I have a problem, and either you resolve it to my satisfaction, or I will reveal your identity to the forum and try to damage your business. I have been impressed with the patience and attempt to help this individual. Clearly no amount of reasoning with this person will help to alleviate what is becoming clear is a psychological problem. This person does not need help with his car as much as he needs help with his head. To the person in Germany that tried to direct him to professional help with his car. Do you know of anybody in the vicinity that can help him with his particular neurosis?
Is this what you do with your retired time? (troll people) enough said! hahahaha you watch oprah? enough saiiiiiidddd!!!! I did not threaten anybody unrealistically!! when someone causes damage to your car , and your of the road for a month!!! This person or business now has a responsibility to either rectify the issue and you never return there after that , or you take them to a court and dont threaten them but enforce it upon them. What did you expect me to do, blame myself ? Go be a victim for your own vehicle, Ill take care of my own. What channel is Oprah on these days. AHAHAh
Reply 0
Feb 21, 2016 | 04:38 AM
  #111
Quote: Well if the company makes them and recommends them for the car, where exactly is the problem there ? Do you plan to keep your car more then 80,000kms from its reading today? I think my logic is actually right then
I don't care for the rest of this thread any more, which has descended into shameful sport, but I still don't understand this comment.
NGK do not recommend BKR6EGP for the SL65, they recommend the IFR6Q-G. Notwithstanding that, I do actually agree with you that platinum/nickel plugs should work instead of iridium/platinum plugs. Regardless of what others may say, it really doesn't matter if you buy cheaper plugs that don't last as long, as long as they work, but they don't.
Now, maybe some retailer recommended BKR6EGP to you, just because they read something 15 years ago that recommended these plugs for the new NA V12. That's about the level of knowledge and intelligence that you can expect from automotive retailers. I suppose you could say they do their best, but they have a large number of parts, and a large number of applications to deal with, and a simply unmanageable number of combinations of parts and applications, so they don't really stand a chance of getting everything right with the time available.
Does it really matter? What's the real cause?
  • Did your engine work with the wrong plugs? Yes.
  • Did your engine start misfiring when you remapped it? Yes.
  • Did the tune cause the misfire? Well, it was working before, and it didn't work afterwards, so it looks like it did.
But there's a missing piece of information here:
  • What would have happened if you loaded the tune but left the old plugs in? Maybe that would have worked, but we'll never know. You changed two things, and its difficult to know which is responsible.
The voltage required to generate the spark increases roughly in proportion with the length of the plug gap. So if you increase the gap from 0.7mm to 1.0mm, you increase the voltage required by about 40%. The voltage required to spark also increases roughly in proportion with the pressure of the air, and your tune probably increased the max boost pressure from 1.5 to 2.0 bar, or something like that. I don't know what the increase in compression pressure is, but it's at least 20%.
Therefore you're giving the coil packs 70% more work to do. All engines are built with some safety and reliability margin, otherwise tuners wouldn't be able to do anything. They have to work within the margins available to them. The coil-packs are known to be weak links, but I suppose even they must be able to cope with - I don't know - maybe 30% extra load. But 70% is almost certainly asking too much of them.
Therefore, in this instance its probably the combination of the bigger gap and the higher boost which is causing the coil pack failure.
Nick
Reply 0
Feb 21, 2016 | 05:36 AM
  #112
Quote: I don't care for the rest of this thread any more, which has descended into shameful sport, but I still don't understand this comment.
Nick
I was thinking exactly this ^^^^ but could never turn the clock back to ask the question, however to be honest how you put it that the voltage will need to increase 40% more is inaccurate , I dont want to argue anymore honestly , I had the same plugs in and car was running fine. It was since I did the tune the car just went to foul mode, not sure if the settings for US Mercedes are different to Australia mercedes and loading the tune settings for another country may have interfered with the ECU/PCM but I need to get to the bottom of this, before I was having misfire codes on both banks on different cylinders, now it seems there just on the 1,3,5 cylinders hhmmmm , and arent changing anymore. I hope "Jerry" @ Eurocharged is able to sort it out for me, he's working close with me to resolve the issue. Sent me a "Euroflash cable" last week in the hope we are able to datalog and record information of whats going on here.
here are the codes I'm getting at the moment
*** Welwynnick did you end up getting the configs for how you tested the coils ohms?
Just got SL65 V12 tuned ! but splattering :(-img_8733.jpg
Reply 0
Feb 21, 2016 | 05:41 AM
  #113
Nick,I like your approach to help him in a rational manner. But he is holding back important information and does not really want to answer the important questions.Maybe he can not or maybe he will not. We don't know how he drives, how he scanns and erase codes,if he can change and regap plugs himself.,who recommended the wrong plugs,who did the plugs,who services his car, how it was serviced in the past etc etc.
Too much variables for me. According to the tune - a good tune does not add that much more boost only approx.0,2 bar from midrange to the Top. More the stock turbos can not deliver healthy -efficient.
Reply 0
Feb 21, 2016 | 05:46 AM
  #114
How i drive and who services my car was never asked , I dont push my car to its limits or anywhere near them. I drive this car as a normal car and every now and then give her a little squirt. In terms of servicing I do what I can as I have been in the auto industry for 15 years, anything thats beyond me which would be example "needing a hoist" or "engine crane" I will take to a workshop to perform. These cars are not as complicated as you might think. They are like any other car just with a few extra cylinders , and two turbos. Its not a Bugatti Veyron
Reply 0
Feb 21, 2016 | 06:03 AM
  #115
I asked you if you are boosting and how long - when you push the car never to the limits how you really are so sure that the old plugs worked fine, see what I mean? To me it sounds that you have the old spark plugs in and nothing changed at the moment and know you are seaching in the dark for the problem.
You will never find the fault that way.Now you need professional approach, help of someone who solved this problem before or change part for part. I would start with the correct plugs, but this is only my opinion. With the wrong plugs you will not have much joy with the tune. And the error codes say there is more going on - dont know how deep yor scan device can erase codes - but I think with all of these codes you will need STAR Diagnosis. With Star you can measure voltage in the coils and much more - it has deeper access to the ECU than normal scan device.
Reply 0
Feb 21, 2016 | 07:51 AM
  #116
Quote: I asked you if you are boosting and how long - when you push the car never to the limits how you really are so sure that the old plugs worked fine, see what I mean? To me it sounds that you have the old spark plugs in and nothing changed at the moment and know you are seaching in the dark for the problem.
yeah I should of got a STAR ages ago! I didnt think STAR was able to actually do this , are you certain it can go that deep into diagnosing voltage on coils ?
* no old plugs are removed new ones are in, they are just fine by the way
Reply 0
Feb 21, 2016 | 11:22 AM
  #117
At least on my SLK32 AMG it could, so it should also on the 65, although it has different coil packs. What makes me think is your error codes 603 and 203 and in addition 2 more unknown error codes. So there is more to do, you need experience with these cars. Maybe disconnecting the battery helps to clear more codes.But some codes only can be cleared with STAR.
Reply 0
Feb 21, 2016 | 11:41 AM
  #118
battery has been disconnected for days! still got these codes, I dont know how the other banks misfire codes just automatically disappeared on there own and never came back. I want to get to the bottom of this dam problem its taking forever
Reply 0
Feb 21, 2016 | 07:23 PM
  #119
SL65MONSTA
you say that money is not the issue, so take it to a dealer and find out what you need to fix this car
I have been a master tech at dealers for 31 years and in that entire time I have never tried to work on my wives diamonds.
do you understand this....
Reply 0
Feb 21, 2016 | 09:42 PM
  #120
This is just a joke..... I still don't know why this thread is going other then comedy. He modded his car and now its broken and its not his fault. His coil packs and plugs were just fine for the last 10 years.....
Reply 0
Feb 21, 2016 | 10:07 PM
  #121
Quote: This is just a joke..... I still don't know why this thread is going other then comedy. He modded his car and now its broken and its not his fault. His coil packs and plugs were just fine for the last 10 years.....
This one will likely get closed at some point by the mods like his other rant thread, but who am I to say? I have been expressly prohibited from posting on the OPs threads. By whom you might ask? Well the OP of course.
My recommendation:
Reply 0
Feb 23, 2016 | 07:27 PM
  #122
Its sad that close to a month has gone by with nothing but a lot of crying and flexing in the mirror. Coils and plugs could have been there and installed. If there was a way to determine exactly what is wrong you would have gotten that information by now. Getting pieced together home-refurbished coil packs will most likely lead to pre-mature failure and you will be right back at blaming the tuner when you are avoiding the proper repair. Suck it up get new coils and the correct plugs for reassurance. If that is not it, you will have to go for the ignition module. You haven't had a chance to even see what the car can do. After all that if you don't like the tune then complain.
Reply 0
Feb 23, 2016 | 10:22 PM
  #123
I may have jumped the gun and complained about the tuner in my other thread and I do owe Eurocharged an apology for putting all blame on them. Like I said I was not warned about this, and if i was I wouldn't have tried to tune my car. Jerry @ Eurocharged is working with me to eliminate what my issues are, its not that money is or isn't an issue, it could be something as simple as a bad injector from what I have researched. Maybe the coils are old but there still working , so to go and change them right now is not necessary, when the time comes for a coil change if I still own the car I will do that no problem. Don't hate on my thread because I choose to utilise not throwing my money away on new coils, ign modules, new plugs, then say "uh huh, it was a bad injector!" , you guys complain about me "ranting" hear you lot! all you do is come on here throwing recommendations that have no logic to them! If you guys cant figure out what the problem is with my car, and Eurocharge cant , its pretty much guaranteed a MB dealer wont be able too unless they start to do what a lot of people on this forum have described there MB dealers do when confronted with this problem! time will tell what it is and you might have learnt something that a $100 injector does not mean spend $8000 on parts working !
Reply 0
Feb 23, 2016 | 11:23 PM
  #124
Quote: Where are you located in Australia?
International Autohaus St Zetland has a good reputation with tuned AMG's in Australia.
If I were you, I would let them check your coil packs and make a professional analysis of the error codes etc. and maybe they have some coil packs to test if they are causing the problem.
Good luck!
post #59 of 123 gave you the best advice.
take it to a professional, pay to have it diagnosed and you will know.
Reply 0
Feb 24, 2016 | 02:20 AM
  #125
Quote: If you guys cant figure out what the problem is with my car, and Eurocharge cant , its pretty much guaranteed a MB dealer wont be able too unless they start to do what a lot of people on this forum have described there MB dealers do when confronted with this problem! time will tell what it is and you might have learnt something that a $100 injector does not mean spend $8000 on parts working !
Man, you don't get it - this is my last post here in this thread.
YOU DON'T READ - I recommended International Autohaus - THIS IS NOT ONLY MB DEALER.
Do you know why I recommended them ???
They BUILT the fastest C63 in Australia 9 Second car on 1/4 mile- and are EVOTECH-Software Dealer for Australia, 800-900 HP MB Turbo-Projects - they are laughing about your little problems with missfire.
You say SL65 is no rocket science - but for you it is!!!
Get this job done by a professional who has experience - and IMPORTANT : Direct access to your car - can work PHYSICALLY on your car!!! Not only over phone or E-Mailing and going back and forth - ahh my plugs are good, ahhh my coils are good - I will repair them by myself.
What a bull****...
Reply 0
