SL55/63/65/R230 AMG: Replaced Front right strut on SL65 amg?
The suspension height is controlled by the external lever arm level sensor that links to the upper wishbone.
Its not the strut, but I'm sorry, I can't suggest what the problem is. It sounds like height calibration, but that shouldn't be affected by replacing the strut. they must have done something else.
Nick
The new vs old struts can't cause this, our cars are self-leveling with a hydraulically actuated suspension. There is a standard coil spring in each strut, however even if the coil in the other side is worn/weaker the ABC will just increase pressure to that strut to raise the height and level car.
Since your ride height has been 'recalibrated' it may need to be set once again. They may have bent the height adjustment arm when changing the strut?? Make sure the suspension height is set on a flat, level surface. Car loaded normally. Adjust each corner to the vehicle height required (measure at fenders) not by the height sensor readings on screen in star. I think the Actuations have to be saved/applied to actually stay. I haven't adjusted my height through star and instead have adjustable links. I'm sure someone here has more info.
You may want a dealer to do it / tech more proficient in operating star system.
