SL55/63/65/R230 AMG: 2014 SL63 oil use
Old Mar 22, 2016 | 07:07 AM
GAD's Avatar
GAD
S63L SL63
2014 SL63 oil use
Hello, I have noticed over the last few thousand miles my 63 is using 1-2 litres of oil every 400-600 miles. The MB dealer assures me this is common but other non MB mechanic friends believe there is an issue.
I have a black SL63 just got up to 18k miles. Always serviced and wants for nothing.
Any help or advice would be great
Old Mar 22, 2016 | 11:13 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
You have warranty, and it has been reported, so relax and enjoy.
S8
Old Mar 22, 2016 | 11:47 AM
GAD's Avatar
GAD
S63L SL63
I understand it's under warranty but would like a definitive answer. 🙈
Old Mar 22, 2016 | 01:02 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
GAD, are you in the US? IF so, I would call MBUSA and see what their take is on the oil use if you don't get a response with any sense of urgency from the dealership. If MBUSA responds with that is within the parameters of normal usage, I would get an attorney and go after them. Lot's of lawsuits from manufacturers trying to sidestep liability from a design flaw. The engines are expensive so they will not want to replace.
Lastly, I recommend you post in the correct forum. You have a 231 and you posted in the 230 forum. Good luck to you.
Old Mar 22, 2016 | 06:18 PM
mark anderson's Avatar
2019 S63,2015 SL63, 2007 SL55, 2006 SL55, 2003 SL55
I think the owners manual says 800 miles and above is normal
Old Mar 22, 2016 | 10:57 PM
mcguirja's Avatar
Mercedes SL63 AMG; Mercedes E63 AMG S 4matic; Mercedes C43 AMG; Mercedes S Class, Mercedes GLK
I have a 2014 E63 S which I believe has the same engine and it isn't burning any oil at all. I think you should push them, that seems like extraordinarily high oil consumption. I haven't seen any threads on oil consumption with the M157 for this year on the 212 forum either that I can recall.
Old Mar 23, 2016 | 01:17 PM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
The problem is that anything above 800 miles / qt is considered normal and will not be considered for any kind of MB paid remediation. My 65 does about 1800 to 2000 miles / qt depending on my driving.
