SL55/63/65/R230 AMG: Dyno numbers in
-Speedriven top mount intercoolers with scorpion intakes
-Speedriven catted downpipes
-Speedriven BOVs
-Speedriven ECU and TCU tunes
-RENNtech heat exchanger
-RENNtech LSD
-Trunk ice tank
-Muffler delete
Pre-dyno, this setup netted 11.1 @124 on drag radials in 95* heat. IATs were also pretty high during runs that day at about 140*.
CDM, who did the installation work for me, went through all the cooling and noticed an H/E pump that wasn't flowing well. We replaced that with a Bosch 010. This netted a drop of about 15* in IATs at WOT to about 125*.
EuroCharged confirmed the IATs on their dyno, noting that cooling is working well on the car.
From there, the car was baselined with the SD shelf tune and netted 589/753.
They then loaded their tune and netted 623/895. 895 rwtq! If I factor in an 18% drivetrain loss, the crank HP number seems right at about 760. Torque-wise, an 18% loss would equate to almost 1100 lb/ft. Holy smokes!
AFRs during the run looked good at just under 12.0 during peak power. Jerry and team are going to strap the car down to see if they can extract anymore power, but as of now, I have a safe and powerful 65 that I hope can finally see 10s!
Thanks Jerry and Eurocharged for getting my car dialed in!
I may remove the engine cover and filters at the track for runs, but don't plan to dyno just to see that dif. I'd definitely say my cats have scraped some hp away.
http://dragtimes.com/Mercedes-Benz--...ag-Racing.html
The typical 65 owner does cooling mods,exhaust, intake and tune. There are a lot more supporting mods and interest for the 55s. There are a few who have really taken the proven mods and perfected them for some really fast cars. I have a lot of respect for those guys.
You are right, big numbers don't always produce the best times, but you also are not dealing with a gutted E55. A full weight car well over 4000 lbs running 10s is impressive. My CL weighs in over 4600 lbs lol.
I think you will have no problem running a 10 second pass with decent weather. Be sure to heat up your tires well and launch at 2500 rpms or better if your brakes will hold you on the line. This will make a big difference with your 60 ft. Also, run the car down to empty and put in some MS109, it will make a big difference as well. Good luck.
