SL55/63/65/R230 AMG: Data logging sensor values ( star ? )
Old Jan 30, 2017 | 04:51 PM
Essell55mb's Avatar
R230 sl55
So, I'm looking to log the values of throttle pedal vs actual throttle position - any ideas how to log sensor values ?
Looking on star you can view 'actual values' but I can't see any data logging type function.
I considered using the torque app, but I don't believe the refresh rate is up to logging value changes with much resolution.
Old Jan 30, 2017 | 05:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You cannot log via Star
Via OBD2 select only 2 parameters to be sampled and the refresh rate should be good.
Old Jan 30, 2017 | 07:29 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Star Diagnosis' Developer Mode will graphically display the values you want. Since it will also print the data, I would suppose the data is logged.
Old Jan 30, 2017 | 07:33 PM
PrecisionEngine's Avatar
'06 SL65
in what platform? under which module?
Old Jan 31, 2017 | 06:58 AM
bobterry99's Avatar
I have not done an exhaustive survey by any means, but I would guess that analog values across all platforms and modules are available.
