SL55/63/65/R230 AMG: '07 SL 55 Air intake temp sensor
Old Apr 26, 2017 | 10:27 AM
560 SEC's Avatar
2011 S550
Can anyone tell how to remove it? Just pull out? Hard to see if there are any tabs
Also the new part is different and says interchange on the slip.
Old Apr 26, 2017 | 11:45 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Press the tabs towards the center and pull upward. If you twist the sensor the tabs will break.
Old Apr 26, 2017 | 08:03 PM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
Where is it located and can a simple gauge be parallel wired to the sensor so as to have a live intake temp reading rather than after the fact looking at a log?
Old Apr 27, 2017 | 04:26 AM
560 SEC's Avatar
2011 S550
Old Apr 27, 2017 | 11:00 AM
shardul's Avatar
It is at the Y pipe portion before the surge tanks.
The gauge will have to be calibrated so the 0-5v signal can be displayed in F.
Why don't you just get a gauge that connects to the OBD2 port and get the IAT readings.
Old Apr 28, 2017 | 07:51 PM
trabots's Avatar
Thanks Shardul, where would I find that? The biggest speed shop in Perth can't help.
