SL55/63/65/R230 AMG: Removal of all ABC components
I got the coil over conversion but now there is a very loud audible clicking sound emitting from my left driver's side, right outside of the parking brake area. I highly suspect it is the pulsating dampener of the ABC. It's basically useless for me and I want to see if I can just singularly remove it. If not, then I would need to find someone else to remove the entire system completely like in one of the PDF I have attached.
I also wanted to ask if the system can be shutdown by STAR programming. What I mean is, are all the components computer controlled and it can be told to shut down by telling it to stop be functioning, or simply put, no longer supply pressure throughout the system anymore?
My guess is no, but worth a shot to ask.
J
You can code out the ABC, search for the coding thread started by Pmercury, it has all the info.
J
If you've pulled the struts, what do you still have connected to the pump?
There are several schools of though as far as disabling/removing the ABC goes. I prefer to fix and keep it but I know that's not for everyone.
