SL55/63/65/R230 AMG: Radio question
Old Jul 4, 2017 | 10:07 PM
Jay Page's Avatar
93 vette
Radio question
So I messed up my radio so how...this is what it looks like....how do I reset it back to normal?
Thanks...
Old Jul 10, 2017 | 01:35 PM
Jay Page's Avatar
93 vette
Help?
Old Jul 11, 2017 | 12:40 PM
Vader1's Avatar
2004 SL55 AMG
It would be helpful to know what you did...
Old Jul 11, 2017 | 02:07 PM
Jay Page's Avatar
93 vette
I think I pressed the wrong combination of buttons. I believe the appearance was different before. You can no longer select stations with the tile.
Old Jul 12, 2017 | 11:49 AM
Vader1's Avatar
2004 SL55 AMG
Did you try to go into engineering mode? I think you can just press back or turn the radio off then on again.
see if that works.
Old Jul 14, 2017 | 12:10 PM
carlsturm's Avatar
I've experienced some intermittent radio issues on my SL65 that are cleared up by an ECU reset. Not sure it will cure your problem but the procedure is as follows
  • Turn the ignition key to the on (not start) position
  • Press the gas pedal to the floor and hold for five seconds
  • Turn the key to the "off" position (don't remove the key), then release the gas pedal
  • Wait at least two minutes for ECU to reset.
Thanks...
