SL55/63/65/R230 AMG: Fuel injector fiber washer
Old Feb 12, 2018 | 11:47 AM
Woodpecker1's Avatar
2003 Mercedes SL55
Question Fuel injector fiber washer
So I started the so called dreaded 82mm throttle body replacement on my sl55 Friday and everything has gone very well up to this point as I still have everything apart because I figured it's a good time to do other things like valve cover gaskets, s/c oil,etc but when I pulled my fuel rack and got ready to change the o-rings out I noticed that these little fiber washers on the injectors were broke any suggestions could not find any washers by themselves or do I just by new injectors
Old Feb 12, 2018 | 08:25 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
they sell injector kits with the orings and whatever is needed
Old Feb 12, 2018 | 10:52 PM
2003 Mercedes SL55
okbarnett could you be more specific as to where I can find the kit Thanks
Old Feb 13, 2018 | 12:02 PM
dRockSL55's Avatar
MBs: SL55, GLK350
you can find the "rebuild" kits at auto parts stores, all over eBay, amazon and I'm sure various site sponsors. The parts are available individually through mercedes as well.
im not certain on the sl55 injector type, can you take a picture of the part number? they appear to be "ev6" style with the jetronic connector (larger and rectangular).
for example go to eBay and search "Bosch injector rebuild kit" and you will find hundreds, with the orings, washers, pintle caps where applicable, filters, etc. Purchase a quality kit for your injector type.
Old Feb 13, 2018 | 12:55 PM
okbarnett's Avatar
dealer should have them in stock
Old Feb 13, 2018 | 03:34 PM
2003 Mercedes SL55
Thumbs up
drocksl55 here is the pic you requested and thanks everybody for the help I will keep searching some more tonight
Old Feb 13, 2018 | 03:45 PM
okbarnett's Avatar
you might look up bosch injectors on web and find a dealer that sells those and parts for them. I know on porsche 928 , 944 the injectors look the same and kist are available from different sellers
Old Feb 16, 2018 | 09:02 AM
dRockSL55's Avatar
MBs: SL55, GLK350
awesome, that is definitely a Bosch injector, what is normally referred to as an "EV6"
Search for "Bosch ev6 kit" online and you will find hundreds of options. They look to be around $15-20 on eBay with everything you need.
Old Feb 16, 2018 | 09:07 AM
2003 Mercedes SL55
Yep I already got them on order through ebay thanks again for your help
Old Feb 16, 2018 | 12:31 PM
okbarnett's Avatar
chean the injector all over with a carb cleaner, assemble the orings with wd40 and they will easily insert into the body. if you have access to a injector tester, you can fire them and check the pattern. but if the car was running good before they are probably fine
